I bought a Endoscope for inner sill inspection
Postby clemo » Thu 18.01.2018, 22:55
Today i bought a Wifi HD 1200P semi flexible borescope camera on a stick that wifi's to any devise.
The end has a camera and a handy little attachable picky upy tool and an excellent adjustable brightness light .
So the the garage i went.
The RED se 92 as a test mule.
finding the right place to poke your tool is quite difficult to start with .But eventually you will find places to push it. The end is a stiff 1' piece so that limits the flexibility of angles however the semi rigid wire helps form a decent arc.
Where to look.
Easy way in is through the battery cover . If possible remove the battery ( but not essential ) and to the near side of the battery compartment is a very big hole. from there you can have a good look around and get a fairly decent shot of the sill . the camera is very twitchy .So patience is required. If you get it right you can get a good shot along it .
I couldn't quite get a full reach around and push along up the sill but was good enough to see the parts that rust out . Thankfully there was nothing terrible to see .. just some flaky bits , all very tidy . It was apparent that something has been sprayed down there as it has a creamy look over the matt paint. So much so i had to clean the end of the camera .
Other side ( Petrol flap side )
Slightly more difficult.
will update .
clemo
Re: I bought a Endoscope for inner sill inspection
Postby HJ2 » Fri 19.01.2018, 12:26
clemo wrote:finding the right place to poke your tool is quite difficult to start with
:lol: :clap:
Postby Rambo » Fri 19.01.2018, 20:07
:lol: :clap:
Yeah, probably better off starting at the front before slowly working round to the rear :bananasex:
Postby alan e » Fri 19.01.2018, 20:44
And do it when you are pissed that also helps :D
Well that's what you think at the time.
Black 1992 M100
2010 black evora
Austin 7 1932 box saloon
BMW X5
alan e
Postby GeoffSmith » Fri 19.01.2018, 20:48
Postby HJ2 » Fri 19.01.2018, 21:08
Petroleum ruins the rubbers !!!
Postby Rambo » Fri 19.01.2018, 21:21
Hope Mrs Clemo's not reading :evil:
Postby GeoffSmith » Fri 19.01.2018, 22:31
HJ2 wrote:Petroleum ruins the rubbers !!!
There's always one! Here's one especially for Clemo's multi-use rubbers.
:bananasex: :bananasex: :bananasex: :bananasex: :bananasex: :bananasex: :bananasex: :bananasex: :bananasex: :bananasex: :bananasex: :bananasex: :bananasex: :bananasex:
Postby Steve A » Wed 24.01.2018, 17:19
Dare I ask it :P
Have you got any probing images you can show us Dave :oops:
Postby HJ2 » Wed 24.01.2018, 23:32
Steve! :shock:
Too much information!!!!! :smt031
Postby clemo » Sat 27.01.2018, 21:43
Right you mikey taking lot !.
It came in quite handy today when probing IB10 .
And yes it can take pictures when deep in the cavities that have not been touched for a long while.
clemo
Postby John_W » Sat 27.01.2018, 22:46
:smt078
Return to Elan Buying Help
