Steering Wheel Help Required
Re: Steering Wheel Help Required
Postby basher » Mon 09.08.2021, 22:15
Thank you, will do.
basher
Postby dapinky » Tue 10.08.2021, 01:35
Please bear in mind when talking about bosses/adapters etc - the FED cars use a different spline on the steering column to the UK cars (due to the column being compliant with airbags and stuff in USA)
The FED column will take an Esprit wheel directly, but the UK one doesn't as the top splines are different between the 2.......
...... it may make a difference when you try to get an 'off the shelf' adapter/boss -make sure it fits your column!
Postby basher » Thu 12.08.2021, 21:05
Imagesteering wheel in by Michael Baldwin, on Flickr
Im a bit chuffed with this. Worth the aggro.
I like the old wheel but it needs a good clean as it was getting sticky and I love the look of the new with the red of the car.
Thanks for all the help, I wasn't aware you get all these bits.
basher
Postby Rocklobster » Tue 17.08.2021, 16:46
Well done, it looks good. I found the original wheel to be just too big. As you say, it's worth all the agro in the end.
Pete
Rocklobster
Postby basher » Thu 09.06.2022, 20:38
Hi all,
Further to this, it appears that I haven't re-aligned the wheel as it was, because the self cancel on the indicators is not working correctly. It's probably just one side, but so far I've just noticed it isn't working, blasting along with the roof down I notice several miles from the turn I'm still indicating.
I don't really understand how it all works any ideas what I do?
Mike
basher
Return to Chassis & Steering
