MOT time
Postby ppete100 » Thu 07.06.2007, 22:37
Had a M.O.T recently. The tester who I know very well, insists on jacking both front and rear to check binding of brakes and wheel bearing play. Stock brakes on front (greenstuff pads) were fine, handbrake ju.u.u.s.t about passed pulling re.e.e.e.aly hard on lever. Ordered new rear calipers from summit racing.. money gone out of my account, awaiting delivery. Post opinion when fitted.
pete
ppete100
Postby Benmac » Sat 09.06.2007, 15:48
Fitted the new pads about an hour ago and its better again. The old pads had worn slightly unevenly so were assisting with the binding. I'm pretty sure it would pass now so I'm going to put it through as the retest won't cost me anything. Still needs the disc sorting though although the warp is tiny so I'll still get the work done but it'll be good if it has an MOT before that just so it can be moved about without concern.
Frost Silver Elan SE
Starlight Black S2 Exige 240Cup
Benmac
Postby Benmac » Tue 12.06.2007, 15:37
Right, a bit of a garbled message from my mechanic mate's oppo but I think its passed the MOT! Excellent. He's having fun and games trying to get the calipers off now. One came off OK but the other is causing some grief but he's onto it.
Phew.
Benmac
Postby RayD » Wed 13.06.2007, 15:08
Ben,
"although the warp is tiny"
If the discs are otherwise in good condition, I would double check the need for skimming. In the absence of any other retraction device, discs are purposely 'warped' in order to move the pistons back.
Ray.
Postby Benmac » Thu 14.06.2007, 08:44
Interesting, it really is tiny (some properly hard mk1 eyeball inspection 'just' reveals it.
Got it back with a nice shiny new MOT and not even any advisories! The calipers came off fairly easily in the end once some leverage was applied. The bolts had obviously been assembled dry and had stuck a bit.
I'm going to leave the brakes for now although I'll need to get new dust seals fairly soon and next thing to concentrate on is the iffy lock.
The journey back was a hoot in torrential rain and mad traffic. My usual short cut on that route failed as it had flooded! People were driving through but I wasn't about to risk the Elan so had to turn around and tough out the queue.
Benmac
Postby M100 TWO » Thu 14.06.2007, 11:21
Club Lotus are doing a kit for the facelift Esprit which consists of lamps bulbs adjusters and carriers I should imagine they are the same as the elan I cant see them doing two types of development for the lights might be worth a call tel 01362 691144 good luck
john
M100 TWO
Postby Sy V » Thu 14.06.2007, 15:48
Aah
A man after my own age!
Wrong thread John? :wink:
Postby M100 TWO » Thu 14.06.2007, 16:03
Yes a pain in the a--- I had to key it in all over again as I do not know how to cut and paste even if that was posible to do
john
you know your getting old, when you get out to the garage and stand there wondering what you wanted out there in the first place, and all the youngsters reading this and smiling, believe me it will happen to you :-D
M100 TWO
Postby ab2cv » Thu 14.06.2007, 16:35
M100 TWO wrote:Yes a pain in the a--- I had to key it in all over again as I do not know how to cut and paste even if that was posible to do
john
Effort much appreciated John...and yes I did smile, a little :-)
Alan
ab2cv
Postby theelanman » Fri 15.06.2007, 12:53
wahoo....I'm now equiped with a shiney new MOT too.....
two advisory note though......
low tread on front tyres.....but I knew that as Ive already ordered another pair
below normal brake force on the rear O/S foot brake......guess thats me stripping a caliper down and seeing whats up.....handbrake was fine.....
anyone any ideas before I start????
cheers
G
Postby ab2cv » Fri 15.06.2007, 12:59
theelanman wrote:wahoo....I'm now equiped with a shiney new MOT too.....
cheers
G
Congrats. If the headlamps I just ordered fit then I should also have an MOT by Monday. :-)
With my rear brakes in the past it's been down to either sticking sliding pins (refurb kit from SJS) or pitted/corroded discs (expensive but SJS do a cheaper version to the Lotus ones)
Alan
ab2cv
Postby Candles » Sat 21.07.2007, 19:40
Just got mine through the MOT: Through first time with no advisories. That has NEVER happened before in 5 yrs of ownership! I'm very pleased!
A tip: Exercise rear caliper pistons in and out before MOT test then work the handbrake and footbrake to move them back to the correct position. This way you'll know they are free.
Candles
Postby rip » Thu 26.07.2007, 23:53
Mine recently failed because of a seized h/b lever. I thought it may do a lot worse.
After a bit of grease and a hammer, I freed it up enough for it to pass, but then it dragged. The next morning, I removed the wheel in order to release it and will avoid using the hand brake until I get my new calipers on.
I have a whole year to sort out bits that annoy me now :D
Postby Monty » Fri 27.07.2007, 17:39
Pinky II has just passed her MOT but with an Advisory on the rear brakes and hand brake :roll: So new calipers and pads for me next year :-D
on the advisory:-
RBT service brake efficiency 51%
RBT Park brake efficiency 18%
Whats should be the efficiency on the elan if the rear brakes are in tip top condition?
Postby Dico » Fri 27.07.2007, 19:10
19% 8)
Return to Chassis & Steering
