METALLIC NOISE IN LEFT TURNS
Postby PHIL70 » Sat 15.04.2017, 12:41
Hello,
I am French and I am the owner of an Elan M100 1992 rhd.
Sorry for my English, it is very poor.
I do not know if I'm in the right section.
I have a problem.
In the left turns, there are metallic vibrations in front of the car like a sheet that touches something but I do not see anything. In the right turns, no problem. Has anyone ever had this problem? (Exhaust ? )
What can be done?
Thank you for the reply.
PHIL70
Re: METALLIC NOISE IN LEFT TURNS
Postby GeoffSmith » Sat 15.04.2017, 16:56
I would start by checking that your brake hose isn't rubbing on the wheel.
USB ElanScan interfaces - Sorry, currently unavailable.
Postby Steve A » Sat 15.04.2017, 19:58
CV joint ? is the rubber gator split ?
Postby Rambo » Sat 15.04.2017, 20:20
I would also check the brake hoses first. If they aren't properly clipped in or tied securely you could end up with catastrophic results !!
Then check CV joint etc, etc...
Goldfish-brain
Postby PHIL70 » Sun 16.04.2017, 10:53
Hello,
Thanl you for the reply.
This week, I am going to check the brake hose and the CV joint with a friend mechanic.
I don't think that there is a problem with the brake hose because it is a very strong noise.
Regards.
PHIL70
Postby PHIL70 » Mon 03.07.2017, 12:54
Hello,
Sorry for the delay. I had health problems.
We found the problem :
It was a plastic protection inside the wing that was broken.
It is why in the the turns, there was a strong sound.
I refixed the part and it is OK.
Thank you and hace a nice day.
Sorry for my english.
Regards.
PHIL70
Postby tigerdog » Thu 13.07.2017, 23:13
Good to hear it was something simple. No need to apologize for your English here. We all speak Elan!
Return to Chassis & Steering
