MOT time
MOT time
Postby Benmac » Tue 05.06.2007, 11:34
MOT tomorrow. Does anyone know if they need to jack the car up to do the test. I've never actually watched a car be done so I'm not sure. I can't see why it would be necessary to check the function and condition of the suspension (that could be done with a full lifting ramp where the car sits on the wheels for a poke around and a bounce test by pressing on the wing to check it all moves as it should) but maybe its necessary for checking the wheel bearings and steering.
I'm going to take a printout of the jacking instructions and I know where they are myself so will watch and scream if anyone goes near the wrong place but I'm just wondering if its necessary to lift it at all?
Frost Silver Elan SE
Starlight Black S2 Exige 240Cup
Benmac
Postby muley » Tue 05.06.2007, 11:53
Benmac,
As far as I know (and in my experience last week) they do need to jack the car (both ends) up to check the wheel bearings and operation of the steering etc.
I have a reasonable relationship with my MOT tester - I have 4 cars to MOT so I see him quite often - and I guide him on the best place to insert his blocks to raise the body. I also tell him to pull bloody hard on the handbrake - which helps ;)
Good luck
Postby theelanman » Tue 05.06.2007, 11:53
ben
the only jacking they do is under the front cross member to check your steeing and frontwheel bearings etc etc.......
other than that its a no.......unless one of your brake line pops like mine did last year :shock:
cheers
g
ps where are you taking it???
Postby muley » Tue 05.06.2007, 11:55
theelanman wrote:ben
cheers
g
Interesting - I wonder how they check the rear wheel bearings at your tester?
Bye for now
Postby theelanman » Tue 05.06.2007, 12:08
having watched him do it.......
its a 2 hands on the top of the wheel and pull/shake......
then same on the leading edge of the wheel...then same on the rear edge of the wheel....roll car forward (90deg rotation of the wheel) and repeat.....then again.......then again.......
its about 12 lots of pushing and pulling on the rear wheel.......
why what should it be??? :shock:
cheers
G
Postby theelanman » Tue 05.06.2007, 12:14
my tester is one of my mates......
known him for 15 years.....we are both diving instructors at the same club....
I too get to suggest easy ways of doing stuff.....I also get to inspect the underside of my cars in great detail.....I have 5 that I take to him and he does them all the same (well except the 67 & 70 elan and the 65 mgb dont get emission test....its not part of the test for them due to their age :-D )
cheers
G
Postby muley » Tue 05.06.2007, 13:06
G,
I'm sure that's fine - it's just that my tester always jacks all the cars up so the wheels are off the ground.
MGB, eh? had one of those for a few years until it finally dissolved away.
Great cars, though. Cheap and plentiful spares, easy to work on, too ;)
Postby Monty » Tue 05.06.2007, 14:17
Don`t know what type of garage Gareth goes to :lol: but all MOT stations need to have the wheels of the ground to check all suspension, ball joint, bearings and tyre condition.
I`ve been going to the same garage with mine and they use the original jack on the correct lifting points. Don`t trust any mechanic with the M100, stay with them and so u can point them in the right direction.
Postby theelanman » Tue 05.06.2007, 16:03
new one on me monty
they can tell when its loose so why should they need to lift the rear end
and getting under you can se the treads......
I remember going under my 67 elan and spotting that the rotoflex/donut for the drive shaft was split about halfway through
he pointed it out to me and then told me that it wasnt a fail as the drive shaft connections were not part of the MOT....but told me about it as it was up to me to repair otherwise itd break and so would the bodywork....so go figure......
he puts it on the ramp.....drives it over the pit.......sticks it on the brake tester.......shoves the emissions thing up the exhaust......
thats about it other than lights, horn, wash wipes, seat belts etc etc etc etc
this is just an MOT station....so he doesnt do any of the work he fails....
not like these garages who fail your car and then offer to repair it for you for some silly ammount of £££££......
:shock: :shock: :shock:
Postby Monty » Tue 05.06.2007, 16:56
You can only check the rear bearings by having the wheels of the ground :roll:
Every car that i`ve had i`ve put through an MOT myself and always stayed with the car so i get a good look at it myself. They always lift the front & rear wheels.
Postby jimbob » Tue 05.06.2007, 21:20
The rear (and front individually) end of the car must be jacked up so both wheels are off the four post ramp at the same time to check wheel bearings, brake binding and general suspension play, unless you've known the guy for 15 years and sellotaped a tenner to the exhaust :D
The mot test station must use a mot approved ramp (as above) and jacking device which rolls along the centre of the ramps length, I would reccomend avoiding jacking the body at all and opt to bring a couple bits of wood or even heavy ruty rubber (4-5''2) and jack the chassis where the front most part of the rear wishbones are bolted on, pretty solid there, use the wood or rubber to prevent chassis paint damage. A lot less stress on the body jacking here. Ever tried to open you car door when its jacked up with the body ? :shock:
08 VW Caddy TDi
jimbob
Postby Benmac » Wed 06.06.2007, 12:41
Well, I'm back from the MOT station. It failed! :(
Everything was absolutely fine and looking really good according to the tester (who took loads of care with the jacking points) until we got to the front brakes, specifically the nearside one. Basically its binding enough to cause a problem in terms of the test. The offside one is doing it a tiny amount too. There is ample power there just the binding, its odd as I can't feel it when driving, it doesn't pull under braking more than a tiny bit which I'd just put down to sensitivity to camber on the road and I haven't noticed it get hot.
Tester reckons that it just needs a strip down and a good clean and exercise of the pistons with maybe a skim of the disc if it has warped a tiny amount. My mate the mechanic who is good mates with the tester reckons the same, especially as the car doesn't get used much. Have booked it in for him to do the necessary next week under the agreement that I'll have a go myself first.
The brakes are the hi spec Billet 4s. What do you lot reckon I should do and what do I need to do to strip them down, clean and exercise the pistons?
Benmac
Postby Sy V » Wed 06.06.2007, 13:08
Oh!
This is the first time that I've heard of the Hi-Spec systems failing an MOT.
Might be worth a call to Hi-Spec and see what they recommend, in the way of maintenance... :?
Hi Spec Motorsport Limited
Unit 7 & 8 Parker Industrial Centre · Watling Street · Dartford · Kent · DA2 6EP · England
Telephone 01322 286850/286827 · Fax 01322 286851
Postby Benmac » Wed 06.06.2007, 13:17
Ta, I'll give them a shout. PNM engineering aren't too far from me either and they're Hi spec dealers. I may give them a shout. First thing I'm going to do tonight is to do a basic strip down just by whipping the pads out (I'm presuming this is fairly straightforward with them) giving the whole lot a bloody good clean with brake cleaner and pushing the pistons in and out a couple of times.
If nothing else doing that will give me an idea if the disc is warped.
Its annoying considering everything else was so solid. I had a good look under the car when it was up on the ramp and everything looked good. Luckily I've got galvanised wishbones so I knew they'd be OK but it doesn't hurt to have a good poke at them. Only other thing that was slightly iffy was the alignment of the headlights which was out a touch (10 second job to get right). Considering that I've just finished refurbishing and rebuilding them and had only aligned them roughly by eye I was happy with that.
Benmac
Postby Dico » Wed 06.06.2007, 16:17
Watch what you are doing with the pistons, if you push them out too far without the pads in you may have a nightmare job getting them back in.
Postby Enright » Wed 06.06.2007, 20:40
Monty was saying elsewhere that he gets through lots of brake pads these days and so gets stuck in with a can of WD40 and a toothbrush around the pistons each time.
I believe he has Wilwoods, but they're 4 pots so the theory is the same.
Postby Benmac » Thu 07.06.2007, 09:02
Cheers chaps. Thanks Dico, I could have done with that tip last night when I pushed one of them too far out :D
OK, I stripped them down and cleaned them up massively. Tried to get the caliper off but it wasn't playing ball and I managed to snap an 8mm allen bit. Luckily its halfords professional stuff so I'll go and get a new one later.
Gave up on that idea and decided to just work on the thing in situ. First I checked the disc. There is a tiny tiny warp in it I think but hardly anything and certainly not enough in itself to be causing the problem. Then I noticed that the dust seals on two pistons had holes in them and were not on properly. No choice but to pull these off, main priority for now being just getting it working again. It seemed to be the bottom two pistons that were sticking so loads of WD 40 and then i just worked them in and out a few times (this is where one got stuck, a careful twist and it goes back in). They're definitely much much smoother in operation now and seemed to be behaving if sticking out a little bit. Then on the last go I was going to do one of the top ones stuck out. Arrrrgggh. Got that back in and then I worked it again. That one seems to be sticky now. I'll keep going tonight with it if I get a chance. I'll also give Hi spec a buzz.
Its odd as I was so pleased that the car sailed through the rest of the test, especially on some of the things I've worked on that were iffy (horn, lights etc) that it makes this all the more galling.
Benmac
Postby muley » Thu 07.06.2007, 09:12
Benmac,
It seems to be working out OK. I'll soon have Hi-specs on so the tips are useful.
(I can't help feeling you've hi-jacked your own thread!) ;)
Postby Benmac » Thu 07.06.2007, 12:14
LOL, yes I do seem to have. Anyway. I've spoken to hi spec who were nice and helpful. Chap there reckons that in the first instance get some hi temp grease onto the piston and work it back and forth a few times to get it smoothly moving and that should do it. If it doesn't I'm to call him back and he'll investigate further.
Benmac
Postby Benmac » Thu 07.06.2007, 17:26
Right I've given them a good going over again and exercised the pistons some more. They all seem to be moving OK but the disc is definitely warped and this is the thing now that is stopping movement being as free as it should. Its loads better though and I reckon would probably pass now.
I've driven it (private road of course) at low speed and they feel absolutely fine. Maybe a tiny tiny bit soft but I did siphon out a small amount of fluid as it was too high after I pushed the pistons back. One thing that is really telling me that its better though is that the car is suddenly loads easier to push! My garage has a tiny amount of forward slope on it to aid drainage and the Elise has always rolled very slowly towards the front unless chocked. The ELan never has. It does now!
I'll get on the blower to hi spec and get some discs as from looking at old threads it looks like they're the only place I can get them.
My mechanic mate is prepped to get the calipers off and then he can get the discs on with the new pads. I'm not going to try myself.
Benmac
Return to Chassis & Steering
