The next big Lotus event this year will be the Lotus On Track (LOT) Lotus Festival to be held at Snetterton Race Circuit over the weekend of 13/14 Jun 2009. Planning is in an early stage but as it is 20 years since the M100 Elan was launched an LEC presence is planned. There will be an attempt for a World Record for Lotus cars and a possibility of a factory visit
by Enright » Sat 13.06.2009, 09:21
rip wrote:Neil - good luck with getting 3rd sorted.
Thanks - half done.
It turned out to be a broken circlip at the lever end of the LH cable.
Now if I can just find another in the junkheap of mine and fit it in time, everything will be fine...
Neil
- Modificator
by Enright » Sat 13.06.2009, 12:17
...except that I can't, so it isn't.
Anybody got any ideas of who might be open on a Saturday afternoon, who might sell honking great 39mm OD x 21mm ID circlips?
Because I'm totally stuffed without one.
Neil
- Modificator
by dapinky » Sat 13.06.2009, 12:23
Just been out to check my Halfords 'selection box' - it doesn't go that big
Can you bodge together a washer held in place with some locking wire?????
- LEC Administrator
by Enright » Sat 13.06.2009, 12:28
Good thought but I don't think I've even got any washers that size. However one of those would be easier to pick up so I'll have a go, thanks.
Neil
- Modificator
by Specky » Sat 13.06.2009, 12:37
Lotus used a couple of varients of circlip, one style was wire the other a flat metal circlip...
I've got pictures of how to undertake a bodge a repair, but I'm a bit busy, but here's the gen in a nutshell
remove cable
remove gearbox bracket
supperglue the cracked cable housing... when it cracks it causes the circlip to fall off
put the cable through the gearbox bracket, find a clip...hose clip etc , anything clippy...
then use a load of aluminum putty over the whole lot, make sure the cable has room to travel back and forth thru the putty and will still lock on the back
wait several hours for curing and refit the cable from the front of the engine...
I'll find the pics and do a proper write up soon
Mine held for months until my AB's arrived
by rip » Sun 14.06.2009, 23:09
nicowalker1 wrote:your cars show mine up a bit though
No way, dude! We all see the faults in our own cars more easily than others do.
I hope you liked the crowd.
Return to Lotus Festival at Snetterton 13/14 Jun 2009
