Jaunt to Nimes and back
Putain, il fait chaud, il fait tres chaud, il fait tres tres chaud, il fait tres tres tres chaud! St Malo to La Tranches sur mer and then to Libourne, blue sky 29-30 degrees hood down of course.
Arrived in La Tranche after excellent overnight crossing to St Malo and lovely drive. All OK with car, well not quite. The passenger window stuck and had to carefully help it closed. And I tried Lotusflasherman's brake fluid test: let the BMC run low and see if the light comes on. It does and it did! Topped up with fluid, cleaned off rogue brake fluid from rear wheel, but absolutely no sign of a leak at all. And I've now done 400 miles since, brakes fine and no wet wheels anywhere. Bit baffling as to why really. Thought maybe a cracked caliper or a faulty piston seal, but no further sign of leaking leaves me dumbfounded but relieved.
Window fixed too: the bolt had come out of the front slider and dropped into the door. Removed door card and speaker, found bolt, refitted and instructed passenger (sorry: instructed Grace) not to use window. So she jumps out of the car at the toll booths to get tickets and to pay. Lovely lady......
Have now done over 600 miles and am in Carcassonne for a couple of nights. What a beautiful "cité": stunning mediaeval fortress - walled town. Will explore in detail tomorrow. Photos will follow too when I work it all out.
perhaps I should say 'less expensive' !!
