Wireless Network advice please
Postby abmunro » Sun 24.01.2010, 21:49
We have Netgear DG834G that it running slow.
We have
Sony Vaio = 802.11 b/g
Dell = 802.11n
Acer = 802.11 a/b/g / draft-N
We have 2 X Box 360's
We also have Western Digital 4 Terrabyte shared hard drive plugged into the router
Can we upgrade to Netgear DGNB2100 N300
Plus a ( WN111 USB Adapter ) for my OLD Vaio with 802.11 b/g
Will the X Box 360's still work?
Tony
abmunro
Re: Wireless Network advice please
Postby markv » Sun 24.01.2010, 23:58
Not sure about the upgrade, but it's definitely worth checking on the Netgear site that you have the latest firmware for your router (but you need to make sure you download the correct update as there have been 4 or 5 versions of that model (I have the DG834G v3 myself). Also, I tend to switch mine off overnight as it gets slow / hangs if left on 24*7.
Postby saska » Tue 26.01.2010, 08:59
abmunro wrote:We have Netgear DG834G that it running slow.
You need to define *what* is slow -- is it internet access, file-sharing between computers in your network. What is slow?
We have
Dell = 802.11n
How do the Xboxes connect to the Netgear -- wired or wireless?
Presumably as a NAS device.
Yes but if it is internet access that is slow then putting it in will not solve your problem.
Try to understand the numbers. Assume you are reasonably close to the exchange and you have an 8MB/Sec broadband connection. The netgear will apportion chunks of that proportionately to each connected device.
So now look at the connected devices. The 802.11G devices are 54 Mb/sec and in real world will do 10Mb/sec but this still exceeds the speed of the broadband connection going through the DG834G. Putting a 802.11N device may give you a faster wifi connection to the router but internet access will be no quicker.
Where you may notice a difference in speed is in file/print sharing within the local network -- like to/from the WD 4Tb.
If you've got too many devices all sharing the broadband pipe then adding the N router won't make that any quicker. Where N can be a real benefit is in the range(distance) of the wireless penetration.
Assuming the XBoxen are G wireless then as long as the wireless setting on the DGN is set to multimode then yes -- it will negotiate the best speed for the connecting device.
Tony
adw (at) saska.co.uk
saska
Postby VagueShot » Tue 26.01.2010, 10:53
Wireless networks are a pain in a**e. I've just hard-wired my stud here and things are so much better, as the bandwdth is a lot higher.
Cut out one or two links if you can with a cable and see how things are.
James Miller
http://anonw.wordpress.com/tag/lotus-elan/ - Ramblings of an anonymous widower and sometimes his ever-faithful Lotus Elan.
VagueShot
Postby abmunro » Wed 27.01.2010, 12:34
Thanks for the info Guys.
I upgraded the firmware and completely reset the router and it has improved a lot.
The printer and WD4tb hard drive are connected via cable all other devices are wireless.
abmunro
