DoT 3/4/5/5.1
DoT 3/4/5/5.1
Postby cliff » Fri 20.07.2012, 22:02
I was talking about new brake pipes with a brake specialist today, he recommended after changing the pipes, use DoT 5, apparently many people driving classics use it. I was a bit surprised so had a quick trawl on the internet. Found these:
http://www.american-auto-club.co.uk/aac ... show&id=70
http://stoptech.com/technical-support/t ... rake-fluid
http://www.type34.com/library/26-techni ... anical/584
It would seem from these articles that if you are installing a completely rebuilt brake system, with components assembled using DoT 5, then DoT 5 is OK.
Otherwise, as has been said many times on this forum, stick to the recommended stuff. The thought of sludge in my brake system does not fill me with confidence.
91 Lotus Elan SE Turbo
Alfa Romeo 159
cliff
Return to Vital Fluids
