broken fuel tank
broken fuel tank
Postby emauri » Wed 07.06.2017, 13:26
Hello all,
I found out that my tank is broken.
I know that someone had it repaired/soldered, but I
am not clear if it is a definitive fix or rather a
temporary thing.
Btw I am in Italy.
Can someone please give an advice
ciao everybody
Enrico
emauri
Re: broken fuel tank
Postby madbilly » Wed 07.06.2017, 13:57
If a plastic solder/weld has not worked then you can remove it and try again, but if you're removing the tank anyway then why not replace it with a new one? You'll probably feel better (but not richer!) knowing the tank is not going to fail again.
madbilly
Postby emauri » Wed 07.06.2017, 14:59
hi
thanks, sorry, I was referring to some posts here, and
someone tried a "fix":
I suspect it only worked for maybe one or two years,
but it's unclear afaik
Personally I did nothing: I only discovered this issue.
thanks and best
enrico
emauri
Postby madbilly » Wed 07.06.2017, 16:37
Ah I understand now, thanks.
Normally, if somebody posts they tried something and they don't say anything else about it then that means the fix/repair worked. If it doesn't work then they post to the forum again explaining their frustration!
So I think this means the plastic welding works, but personally I've not tried it.
madbilly
Postby madbilly » Wed 07.06.2017, 16:38
Thanks BCN, will do :)
madbilly
Return to Vital Fluids
