Home | WikiLEC | Repairs | Upgrades | Gallery | Buy & Sell | Mountain Chips | Meets & Events | Contact |
GeoffSmith wrote:Check the O ring on the rear cam blanking plug. It is the same as the CAS O ring (A100E6562S) and also leaks.
Rambo wrote:GeoffSmith wrote:Check the O ring on the rear cam blanking plug. It is the same as the CAS O ring (A100E6562S) and also leaks.
That's the one Dave didn't do on mine as it was OK . Although I think the main reason was that we were running out of time as it was beer o clock
Simon_P wrote:Please check your oil cooler hoses before starting your engine again - particularly the inner one which is prone to pop off.
I stick with oil in the original recommended viscosity range as I know that's where the testing was done. Lotus did recommend 60 oil but I wonder how much testing they did, or if it was just to standardise?
10w 60 is comparitavely thick when cold and thick when hot.
dapinky wrote:I use the 10W-60 (Fuchs) as my engine is approaching 140K miles..... but only went to the thicker stuff once it was past 110K.... it seems to like it, and keeps a more consistant pressure.
Rambo wrote:PS If your engine ever goes bang at least you can say it's been well Fuched Dave
