oil.....what are you running and what are the 'effects'
Postby theelanman » Sat 12.05.2007, 07:38
as it says above....
with all these oils available who's using what and what pressures are you getting......
the manual says 10w/30 for temps over -20degC....ive just changed to 10w/40 and am getting a higher oil pressure than I was before....
just wondered what everyone else was running and any observations...
also any definative answers on the best to use...
cheers
G :)
Postby paulwatkins » Sat 12.05.2007, 08:47
After my run-in period, I switched to Castrol Edge Sport 0W-40 (same viscosity but not manufacturer as per the service bulletin - which says Mobil 1) but it appears to have found a slight leak somewhere.
It's nothing major, just a thumbprint size patch of oil on the garage floor after a spirited run! It is not a continual leak.
When I was running her in with 10W-40 Duckhams during the run-in, there was no leak, but with the thinner stuff, it has found a gap!
I think I'll switch back to 10W-40 at the next change
paulwatkins
Postby muley » Sat 12.05.2007, 12:49
I've been using Mobil 0/40 for some while, but switched to the Castrol Edge 0/40 last oil change (it was £9 cheaper). According to the spec sheet it is slightly thinner than Mobil at 100deg. - the slightly lower oil pressure bears this out. have used a bit on last weekends run - 500+ miles but the very minor oil leak I had with Mobil has stopped ...
As the car had nearly 70,000 miles I'm thinking of trying a 10/40 partly synthetic - Halfrauds has the Mobil S on special at £23 at the moment - has anyone used this in their Elan?
1995 Palacio S2 no 507
Postby Paul.P » Sat 12.05.2007, 22:30
I use Castrol RS 0/60 fully synthetic , as recomended by many lotus garages. It is quite expensive, but ive never had a problem, & my engine has done 110k now.
Postby kmckmc » Mon 14.05.2007, 09:07
So,
How many people here are using 10w30 oil? What is your operation condition's idle oil pressure according to M100's oil pressure gauge?
I just phoned Mr. Kenny Brown of Motor Engineering Ltd. He told me that a recommended oil pressure is around 2 Bar (M100 in operationg condition at idle).
Are your Elan M100s at 2 Bar ?
Please advise.
Elan M100 S2
kmckmc
Postby theelanman » Mon 14.05.2007, 13:10
sorry forgot to mention that I'm running with 10w/40 as I was before the head gasket change......Ive just got a higher pressure now than I had before.....
is this typical???........will it come down after Ive 'run it in'????
cheers
G
Postby lotuska » Mon 14.05.2007, 18:03
Why would changing the head gasket affect oil pressure??
I though that it was more affected by tolerances on the crank (main bearings etc), oil pump... and therefore would only really change if you've had a complete engine rebuild.
lotuska
Postby theelanman » Mon 14.05.2007, 18:34
lotuska wrote:Why would changing the head gasket affect oil pressure??
I dunno thats why I started this thread.....
since I changed the head gasket Ive noticed that my oil pressure is up about 0.5 bar at idle and 1bar+ under load.....
it used to be 2.5 at idle and 5 under pressure...when warm....
now its 3 at idle and 6.25 under load....
its confused me as Ive not done anything 'special'......and Ive used the same 10w40 oil that I used last time.......
so indeed...why should it go up??......
Ive still gotta run it for 500 miles and do a retorque on the head bolts but other than that its finished......just running at higher pressures now....and am a little concerned until someone tells me otherwise.... :shock:
cheers
g
Postby ailwyn » Mon 14.05.2007, 22:14
G,
This (what is normal oil pressure) has been discussed before.
Mine runs at (when warm) 2.5 bar @ idle, 5 under load. While warming up it's usually around 7.
As I know nothing take no notice of what I say, but I personally wouldn't be bothered with the readings your getting, now if they were a lot lower than before or the needle just pointed north then I'd be concerned.
A.
Postby Simon_P » Mon 14.05.2007, 23:23
Put 0W - fully synthetic in - Made the valve lifters noisey
So switched back to 10W - =quiet again
There seem to be many questions about noisey hydraulic lifters......
Simon
Postby Scott J » Tue 15.05.2007, 10:48
I've been using Halfords 5W/40 fully Synthetic since purchase at 115,000 til now at 142,000.
Kenneth Brown Motor Engineers have never said not too.
Scott J
The prodigal son
Postby kmckmc » Wed 16.05.2007, 14:22
Today I emptied the SHELL 5W40 which I put in last week. I now replaced it with Castrol FORMULA RS 10W50.
So, It runs at (when warm) a bit less than 2.5 BAR @ idle, 5.2 BAR under load. While warming up it's usually around 7.
Have other people tried this one?
Cheers,
Elan M100 S2
kmckmc
Postby Elanlover » Thu 17.05.2007, 20:48
ailwyn wrote: Mine runs at (when warm) 2.5 bar @ idle, 5 under load. While warming up it's usually around 7.
This is exactly what I see. I've just started using Amsoil synthetic Euro spec 5W-40 with their Ea synthetic filter.
Postby Oliver » Thu 17.05.2007, 21:32
kmckmc wrote:Today I emptied the SHELL 5W40 which I put in last week. I now replaced it with Castrol FORMULA RS 10W50.
Cheers,
Ouch! Engine oil is an expensive hobby :!:
My readings seem identical to yours. I`m using Elf 5w-40 full syn. 87k miles.
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
Postby muley » Fri 18.05.2007, 23:53
Scott J wrote:I've been using Halfords 5W/40 fully Synthetic since purchase at 115,000 til now at 142,000.
Hmm, interesting post - as I have been using that oil in the other cars (Ford, Honda) for years and it seems to work well.
Priced for the budget conscious, too ;)
Postby muley » Fri 18.05.2007, 23:55
kmckmc wrote:So,
Please advise.
With 0/40 oils mine show around 2 bar at idle. Slightly under when hot (i.e. when the fans kick in...)
Postby L.G. » Sun 20.05.2007, 00:50
I have another oily thing to say - ask; I've heard that it is not advised to change the viscosity of the oil that's been used for a long time on an engine. It may result in excessive oil consumption and may damage the engine. If any of what I've written is true you should just continue buying the same thing.
To answer the real question, I changed from shell 5w-40 to mobil 15w-50, my pressures haven't changed a big deal (they are pretty much the same as ailwyn's)
L.G.
'95 S2 driver #286
L.G.
Postby JOSLER » Fri 06.07.2007, 06:57
Im running mobil1 0w-40 my friend put me on to this expert on oil and he sent me this info:
Carl,
The 0w-40 is fine, and not too thin.
I would suggest either a 0w-40 or 5w-40 synthetic so your on the correct track.
From us we would recomend Silkolene and Motul as an upgrade.
Guy.
To Order Online http://www.opieoils.co.uk/ <http://www.opieoils.co.uk/>
To Order By Phone CALL GUY on 01209 215164
CLUB MEMBERS SECTION HERE http://www.opieoils.co.uk/Members.aspx <http://www.opieoils.co.uk/Members.aspx>
OUR EBAY SHOP http://stores.ebay.co.uk/OPIE-OILS <http://stores.ebay.co.uk/OPIE-OILS>
________________________________
From: website@opieoils.co.uk [mailto:website@opieoils.co.uk]
Sent: Wed 04/07/2007 14:02
To: sales@opieoils.co.uk
Subject: Website: Oil Recommendation
CustomerTitle: Mr
CustomerName: Carl Joyce
CustomerPhone: 07733326951
CustomerEmail: josler@ntlworld.com
VehicleMake: Lotus
VehicleModel: Elan M100
VehicleYear: 1991
VehicleEngineType: Petrol
VehicleEngineModel: SE Turbo
VehicleModifications: None
VehicleDrivingStyle: Fast road driving
VehicleAdditionalInfo: I'm currently running 0w40 Mobil 1 but am a little worried that it is too thin. It is a recommended Oil in the Lotus Elan Central forum and everyone seems to use it.
Another mate told me that running too thin an oil isn't always good for a turbo.
(This is a copy of the e/mail)
So it seems to be ok to run this oil hope this might be helpful. :smt023
1991 Calypso Red SE
JOSLER
Postby Elanlover » Fri 06.07.2007, 14:54
I have to say, since switching to the synthetic Amsoil the engine seems a bit less noisy.
Postby rip » Wed 18.07.2007, 00:32
JOSLER wrote:Another mate told me that running too thin an oil isn't always good for a turbo.
That's because a Turbo spins at around 150,000 rpm and therefore gets VERY hot.
Modern oils may not thin as much as older formulas when they get hot though.
Return to Vital Fluids
