Having the last clearout of my M100 parts I kept as spares, if anyone is interested in anything off this list please PM me with price offer and I can sort out postage etc at cost and (if you want) insurance. I can send pictures of any of the items as required also, if you let me have an email address.
Timing belt (Goodyear)
Alternator Belt (Gates)
Intermediate roof seal L/H (no bag but new unused and perfect) A100V0123
Window glass slider A100B6211S
Door waist trim finisher LH A100B1085K
Seal (wing mirror to body) LH E100B0815F
Seal (wing mirror to body) RH E100B0816F
Seal (Cheater trim) LH A100B0889F
Seal (Cheater trim) RH A100B0890F
Seal L/H door (later type) NEW C100V0115 - note, although new and not use it has a cut in the long length of straight seal section which has been glued back together. perfectly useable as its the shaped ends that count!
Seal (rear deck, ie the back of the roof to the rear deck) A100B61685
Pair New interior door lock eutchestons/surrounds A100B0090F
New Cheater Panel R/H D100V0058F
Pair New centre dashboard vents
Springs B-Post cap (early type) New set of 4 B100U0240F
B-Post caps (early spring type) New pair (reproductions of superior quality and durability)
Dash switch blank New
Brake master cylinder New non-lotus but direct replacement
Speedo cable genuine Lotus (A100N0001F)
Turbo Head Gasket fully sealed genuine Lotus A100E6104S
Full Engine gasket set for turbo engines, absolutely everything in it! non-lotus fully sealed excellent quality or I wouldnt have bought it!
Pair New unused footwell over mats, matching grey colour leather edge bound shaped to fit exactly.
One New gearchange cable, unused and I cant remember which one it was!
Accelerator cable New genuine Lotus D100L0069F
New Gear lever assembly, never fitted, obviously genuine
New polybush anit-roll bar bush set of 4, never fitted
New mounting ring for headlamp (the white one) genuine Lotus A501M0067
New L/H mirror assembly A100U0498F (no mirror glass though)
New R/H mirror assembly C100u0316F
Reconditioned cooling radiator
Used but perfect centre tunnel/armrest/gearlever surround trim piece, all brackets still attached and not worn or damaged
