water pump and cam belt
Postby Janeyblow » Mon 01.08.2022, 13:37
Hi All,
Like some others here.... engine overheating when stuck in traffic and less than optimum performance from the heater. Fans not coming on.
My local garage tells me it needs a new waterpump and cam belt but tells me that he cannot get water pump or cam belt kit.
Could someone please advise a manufacturer and part number for these please.
Thanks in anticipation
Janey
Janeyblow
Re: water pump and cam belt
Postby muley » Mon 01.08.2022, 16:51
Hi, and welcome
The fans not coming on is probably a separate issue to the water pump and cambelt
It's worth checking the fan switch, their fuses and the fans themselves first.
The parts are normally available at SJS, PNM or can be obtained from Rockauto in the U.S.
There are other posts in this forum to point you in the right direction
1995 Palacio S2 no 507 : 1991 Aqua Blue SE Honda Jazz 1.3
Postby Graaf » Mon 01.08.2022, 17:05
I’ve used rock auto for belts pump and tensioner and other parts. Great value and delivery is not much longer than buying from U.K. based company.
Graaf
Postby Fredjohn » Mon 01.08.2022, 17:21
As already said, fans and water pump/cambelt are 2 separate issues.
In addition to checking switches and fuses, also check all earth connections for the fans. They earth in a vulnerable area and are prone to rust.
Cambelt should be changed every 5 yrs and water pump etc at same time. Here is a link to the Isuzu page at rockauto
https://www.rockauto.com/en/catalog/isu ... 173,engine
PS also put your location in your profile. A local LEC'er may be able to help!
Elan S4 DHC 1969
Evora 2010
MB E250 CDi coupe 2013
Boardman Endurance SLR 9.4 disc 2018
Rapido 746 2010
Postby Tuga2112 » Mon 01.08.2022, 22:05
Fredjohn wrote:PS also put your location in your profile. A local LEC'er may be able to help!
this is more relevant than it appears. you will find some people in this forum are more knowlegble than most Garages out there. if you happen to be local to one of them. their wealth of knowledge will help you a lot on all maintenance issues.
one thing that no one has mentioned is that the fans come on when the needle is around 3/4 of the way up. for a new owner, that is usually something you wouldnt expect. and testing the fans operation is very easy by grounding the thermostat plug to the engine or chassis. (ive done it with a paperclip)
PS, if you are in Durham. send a PM, I'd be happy to help.
1991 elan se
1991 elan se project
91 MR2 Turbo (import) project
94 Celica GT4 (Import)
94 4Runner
98 Celica SR
Postby par » Mon 01.08.2022, 22:48
Following on from the post from Tuga above, when you say overheating is it boiling over or are you assuming it is overheating from the temp gauge?
It is normal for the needle to stay just off the bottom of the scale when driving and to then rise dramatically to around the 3/4 mark when stationary which is quite alarming until you realise this is normal. It has caught myself and others out upon first taking ownership of an Elan.
Not saying cambelt and waterpump may not need doing but it is worth understanding if your car is really overheating.
HTH
par
Postby Kipperozzy » Tue 02.08.2022, 08:31
If the heater isn’t getting hot when the engine is, usually that’s due to an airlock in the cooling system. Have you bled the radiator using the plug under the near side headlight pod . Possibly the heater valve is siezed closed as these are also suspect often need replacement
Kipperozzy
Postby Janeyblow » Tue 02.08.2022, 12:11
thanks everyone.... all very helpful and noted.... I'm on it.
BTW I'm in the East Midlands
Thanks again
Janey
Janeyblow
Postby Richmmm » Tue 02.08.2022, 12:51
For info, I have just taken delivery of a water pump, timng belt and idlers, from Rock Auto.....Cost about £80 delivered in about 5 days.
Rgds Rich
Richmmm
Postby HJ2 » Tue 02.08.2022, 14:33
Kipperozzy wrote:If the heater isn’t getting hot when the engine is, usually that’s due to an airlock in the cooling system. Have you bled the radiator using the plug under the near side headlight pod . Possibly the heater valve is siezed closed as these are also suspect often need replacement
It is worth to have a look at the t(r)usty heater valve as well then.
Postby Rambo » Tue 02.08.2022, 21:28
See Dapinky's Rockauto order below
viewtopic.php?f=33&t=29273&p=372793#p372793
Return to Heating and Cooling
