Heater matrix
Re: Heater matrix
Postby lotusnut » Sun 22.12.2013, 20:19
I replaced my matrix last year, the old one was blocked solid, nothing would pass through, not even compressed air. When I got it all back together the heater was brilliant, as Lansledj said well good enough for this cold weather. Also I put some commercial cleaning/flushing fluid into the old matrix without diluting it and even that would not clear it. To replace the matrix is a complete dash out job, not a 5 minute fix. You could try disconnecting the two pipes under the bonnet and connecting a hosepipe and flushing through both ways but I wouldn't hold out much hope. By the way,If you had thought of fitting a Lambda sensor (if you haven't already got one fitted), its much easier to run the wires when the dash is out. Good luck.
1991 Elan SE Turbo, 1976 Elite 501,1975 Elan +2S 130/5 and Golf TDi
lotusnut
Return to Heating and Cooling
