Electric Coolant Pump 'piping'
Postby david.bradley » Sun 24.01.2016, 09:29
I've had the car 15+ years and only realised in the past year that the electric coolant pump had been bypassed, but the pump left in place.
I've got a replacement as a precaution, and intend to fit. I guess the old one was bypassed as it didn't work
What I dont know is which pipes fit where on the pump itself.
The Wikilec talks about replacement options, but for obvious reasons assumes you took the pipes off in the first place.
david.bradley
Re: Electric Coolant Pump 'piping'
Postby Brit-Car-Nut » Sun 24.01.2016, 19:38
Maybe this will help?
Postby david.bradley » Sun 24.01.2016, 22:11
Thank you
I often have a problem with photos, and get this message.
'You do not have the required permissions to view the files attached to this post'.
Would anyone please know what I have to do to resolve ?
david.bradley
Postby Fredjohn » Sun 24.01.2016, 23:25
david.bradley wrote:Thank you
Easy: log in!!! :D :D :D
Some pictures are only available for viewing by registered members so you cannot see them till you log in.
Elan S4 DHC 1969
MB CLK 320CDi 2007
Evora 2010
VW T4 Campervan
Postby epipete » Mon 25.01.2016, 09:39
Too simple. Surely you can't post if your not logged in!
Postby Fredjohn » Mon 25.01.2016, 10:41
epipete wrote:Too simple. Surely you can't post if your not logged in!
This had occurred to me too!! But decided he may not have revisited BCN's post when placing his own and so not seen the pictures. If not then it is indeed far more complicated and I have no solution.
But David if you look at the workshop manual in the cooling section you will find the same pictures and more
They are available from the link at the bottom of BCN's post.
Elan S4 DHC 1969
MB CLK 320CDi 2007
Evora 2010
VW T4 Campervan
Postby epipete » Mon 25.01.2016, 16:15
Sorry John, when I posted this it wasn't meant to read so curt, no offence intended!
Postby Fredjohn » Mon 25.01.2016, 17:13
None taken Pete: you made a very valid point!!!!!!
Elan S4 DHC 1969
MB CLK 320CDi 2007
Evora 2010
VW T4 Campervan
Return to Heating and Cooling
