Header Tank Strap
Header Tank Strap
Postby lotusles » Tue 26.01.2016, 21:50
Hi, just about to fit some gear cables and decided to replace the header tank at the same time.
Does anybody know if the S J plastic tank is the stronger ribbed version, plus does anybody know where I can get the rubber strap that keeps it in place or suggest an alternative.
Many thanks
Les
lotusles
Re: Header Tank Strap
Postby Rambo » Wed 27.01.2016, 10:21
Most people use no strap as the original has perished away many moons ago. It does virtually nothing anyway and the tank sits perfectly in place without it. Unless you were restoring your Elan to concours condition, I wouldn't bother.
With regard to the tank, the replacements have been known to split easily and there have also been problems with the (yellow) pressure cap. Again, I wouldn't bother with replacing as the original has done well for the last 25 years or so and can be cleaned up well with a bit of patience.
Goldfish-brain
Postby rip » Wed 27.01.2016, 13:59
Rambo wrote:Most people use no strap as the original has perished away many moons ago. It does virtually nothing anyway and the tank sits perfectly in place without it. Unless you were restoring your Elan to concours condition, I wouldn't bother.
Postby GeoffSmith » Wed 27.01.2016, 16:12
Rambo wrote:Most people use no strap as the original has perished away many moons ago … and there have also been problems with the (yellow) pressure cap.
Strap? What strap? Maybe it was an S2 added lightness feature like the missing rubber boot on the boost sensor.
What problems with the bright-yellow-to-make-it-easy-for-learner-drivers-to-pass-the-driving-test caps?
USB ElanScan interfaces - Sorry, currently unavailable.
Postby Rambo » Wed 27.01.2016, 16:20
Wasn't it something do do with the incorrect pressure rating or the fact that they leaked ? I can't quite remember but I've now reverted to the OEM cap.
PS Lotus were right cheapskates when they made the S2. Or was it Bugatti back in the mid 90s? :shock:
Goldfish-brain
Postby GeoffSmith » Wed 27.01.2016, 16:52
I think someone once got PSI and kippers (kPa) mixed up, and so the tale of the 100 PSI yellow cap began...
Postby dapinky » Wed 27.01.2016, 18:09
The 'issue' with the pressure caps was nowt to do with the colour - it was the fact that some sealed properly and some didnt......
..... if you get a £2 yellow one from China it doesn't seal as well as a £6 yellow one from Germany.
Perhaps they use cheaper yellow paint in China???????
Postby lotusles » Wed 27.01.2016, 19:27
Thanks everybody, stick with the original and the black cap it is then.
lotusles
Postby Rambo » Wed 27.01.2016, 21:03
Here's some information and history on the coolant tank problems for your info.........
viewtopic.php?f=29&t=20543&hilit=Header+tank
PS I'm fairly certain JohnW found something good for cleaning his header tank. Can't remember if it was Milton's sterilising fluid or a Steradent but a search might yield the right info.
Goldfish-brain
Postby GeoffSmith » Wed 27.01.2016, 21:50
Rambo wrote:PS I'm fairly certain JohnW found something good for cleaning his header tank. Can't remember if it was Milton's sterilising fluid or a Steradent but a search might yield the right info.
JohnW..... more likely to be Steradent.
Postby Rambo » Wed 27.01.2016, 22:16
Mixed with some Viagra, cod liver oil, raw garlic and glucosamine :-D
Goldfish-brain
Postby GeoffSmith » Wed 27.01.2016, 22:47
I thought that was you swivel hips.
Postby Rambo » Wed 27.01.2016, 22:58
:lol: Still going strong though :bananasex:
Goldfish-brain
Postby Simon_P » Wed 27.01.2016, 23:52
dapinky wrote:The 'issue' with the pressure caps was nowt to do with the colour - it was the fact that some sealed properly and some didnt......
Dave,
It is more the Chinese header tank doesn't work with the yellow cap but it does with the black one - This I have tested with Old new header tank and yellow/black cap. 2 different cars on the same day. The yellow cap on the replacement header tank had a hot wet moment all other combinations were ok. That said I didn't ask the yellow cap if it was Chinese, and it didn't speak German.
Postby Simon_P » Wed 27.01.2016, 23:57
GeoffSmith wrote:Strap? What strap? Maybe it was an S2 added lightness feature like the missing rubber boot on the boost sensor.
S2's had the strap... but it fell off before anyone had heard of Tytherington!
Postby dapinky » Thu 28.01.2016, 10:34
Simon,
As I'm sure you (and everyone else) guessed, i was being flippant with the cap nationality - just trying to emphasize that cheap caps, whatever their colour, are likely to be 'not as good' as more expensive ones.
I currently use a yellow cap with no problems, but the first one I tried leaked like a sieve and I couldn't ever get it to seal properly.
I noticed on the cheaper one that there was a shallower depth of threaded portion on the cap so it didn't have anywhere like the contact area between the tank and cap, but the other one was much deeper - like the OE one (black!).
Postby Rambo » Thu 28.01.2016, 10:45
dapinky wrote:As I'm sure you (and everyone else) guessed, i was being flippant with the cap nationality - just trying to emphasize that cheap caps, whatever their colour, are likely to be 'not as good' as more expensive ones
Header tank cap bigotry. They'll be getting a new Minister in Brussels before you can say Weston Super Mud :lol:
Goldfish-brain
Postby GeoffSmith » Thu 28.01.2016, 10:47
Get back to your tapas and Cava.
Postby Rambo » Thu 28.01.2016, 10:55
Great idea, but a little early :drunk:
Goldfish-brain
Postby John_W » Fri 29.01.2016, 12:24
I'm a little late to spot this calumny.
I would like it on record that it certainly wasn't me that found anything to clean the header tank.
Philistine
Return to Heating and Cooling
