Please tell me this isn't what I fear it is
Postby Saltire » Sun 02.10.2016, 14:34
2010 Fiat Panda 100HP, bossanova white/grey (the rollerskate)
2017 BMW F48 X1 2.0D AWD, Mediterranean blue/magnolia (the workhorse)
Re: Please tell me this isn't what I fear it is
Postby epipete » Sun 02.10.2016, 14:45
It's either severe anaemia or a coolant leak! But it needn't be as grim as you fear. That is, depending how far under it goes, below the valve in the headlamp recess, the electric Coolant pump and various pipes. Need to verify where from before you panic.
Postby alan e » Sun 02.10.2016, 14:45
Are you using pink antifreeze? That is below the air cooler for the turbo but it maybe a water leak from a hose or the electric water pump which is above.
Black 1992 M100
Austin 7 1932 box saloon
BMW X5
alan e
Postby muley » Sun 02.10.2016, 14:54
..or the bleed screw
JIm
1995 Palacio S2 no 507
Postby epipete » Sun 02.10.2016, 15:01
D'you know, funny but I thought I said all that :bonk: :banghead: :shock: 8) :P
Postby GeoffSmith » Sun 02.10.2016, 16:15
alan e wrote:Are you using pink antifreeze?
Looks like it is OAT which will corrode any brass (sensors) in the system.
Postby alan e » Sun 02.10.2016, 17:44
epipete wrote:D'you know, funny but I thought I said all that :bonk: :banghead: :shock: 8) :P
Check the time of my post and your post great minds and all that :D
Black 1992 M100
BMW X5
alan e
Postby Saltire » Sun 02.10.2016, 19:07
epipete wrote:It's either severe anaemia or a coolant leak! But it needn't be as grim as you fear. That is, depending how far under it goes, below the valve in the headlamp recess, the electric Coolant pump and various pipes. Need to verify where from before you panic.
Having had the chance of a slightly longer look this afternoon, it seems to be dripping off the rear corner of the black undertray immediately behind the rubber lip spoiler.
I confess to my shame that I had never actually checked the colour of the antifreeze since I bought the car. Sounds like a good opportunity to a) trace the leak properly, and b) fit a set of Samco hoses before a flush and refill. Yet more work to do over the winter :?
Postby GeoffSmith » Sun 02.10.2016, 19:56
Remove the undertray Jonathan. Based on personal experience, a leak from a) radiator end caps (either end), b) recirculating pump, c) bleed valve, d) top/bottom hoses to the rad, e) coolant hose to the block, f) the dreaded Y hose and g) the PAS pump banjo [I presume you have confirmed it's not oily] will all result in a drip at either end of the undertray depending on the angle of the car.
Postby Saltire » Sun 02.10.2016, 20:29
Thanks, Geoff (and indeed everyone else) for the helpful suggestions. It's just coolant; there's no sign of any oil content :D
Unfortunately I'm away all week again on business, and then we're off to see some friends of Pauline's next weekend (yawn), so axle stand action will have to wait a while. The good news is that I've wiped it up around lunchtime today and it hasn't recurred. However, that doesn't mean I'll be ignoring it . . .
Postby Rambo » Sun 02.10.2016, 20:35
Jonathan - When you've sorted the leak, get the coolant drained and flushed. And do yourself a favour and replace that horrible pink OAT antifreeze, and replace it with the blue ethylene glycol stuff. The pink stuff is no good for the old engines :(
Postby Saltire » Mon 03.10.2016, 07:48
But Rambo, isn't that the same OAT that my motor factor assures me is suitable for all vehicles, and the best thing since sliced bread? And is that anything to do with the fact that he holds a (very profitable) dealership for the said brand?? :evil:
Seriously, I don't like the pink either, and if I'd known it was in there, I'd have flushed and refilled months ago. It simply never occurred to me at someone might have been daft enough to fill a 1990s engine with OAT.
thanks again for the wise counsel.
Postby Nickydee » Mon 03.10.2016, 13:35
Our friend Toby has addressed this in one his videos which is up to his usual informative and witty standard.
https://www.youtube.com/watch?v=tfj3dUZTYJY
Postby Saltire » Wed 05.10.2016, 19:28
Thanks, Nick, I'll take a look :clap:
Postby discovery1 » Sun 09.10.2016, 17:28
From GeoffSmith post - the dreaded Y hose ???
discovery1
Postby discovery1 » Wed 19.10.2016, 20:36
Can anyone explain what GeoffSmith means by the dreaded Y hose?
discovery1
Postby John_W » Wed 19.10.2016, 22:43
There are three y hoses. One is at the front of the engine, attached to the electric recirculating pump, one is at the other end of the same pipe where it attaches to the bottom radiator hose and the third one is at the rear, going to the heater valve. The one Geoff is referring to is the one that broke on his car (whichever was the one at the rear of the engine). viewtopic.php?f=28&t=24824&p=323338&hilit=Hose#p323338
Postby esprit888 » Thu 20.10.2016, 01:08
discovery1 wrote:Can anyone explain what GeoffSmith means by the dreaded Y hose?
As mentioned there are three of them, I have new and used, they look like these:
esprit888
Postby simonbuk » Thu 20.10.2016, 08:39
It probably means that you are about to lose a lot of skin off the top of your knuckles !!
simonbuk
Location: Orpington, Kent, sometimes Worthing, West Sussex sometimes The World !!
Postby epipete » Mon 14.11.2016, 07:54
Just get 'em all out, nasty old pipes, and replace all the plumbing with some nice new shiney Samco's
Return to Heating and Cooling
