Anchors and gotos
Read here for help with getting started on postings.
Anchors and gotos
Postby maz_r » Sun 21.05.2017, 14:25
A feature has been added that allows you to put 'sub-sections' within a post such that you can add clickable links into a long post.
To do this, you need 2 elements:
Firstly a point to jump to, which is called an anchor. This is added by inserting this code into your post:
[anchor=YourAnchorName]Your displayed anchor text[/anchor]
Obviously, YourAnchorName is whatever you decide to call it and needs to be unique within your post. Similarly, Your displayed anchor text is what will be displayed as a sort of section heading.
The second element is a 'goto' This displays a link, which can be clicked on and this will scroll to wherever the corresponding 'anchor' is. You can include multiple 'goto's which will all scroll/jump to the same place. Add a goto using the following code in your post:
[goto=YourAnchorName]Your displayed link text[/goto]
By way of an example, the following code:
Code: Select all
[anchor=contents]Contents[/anchor]
[list]
[goto=testanchor1]Section 1[/goto]
[goto=testanchor2]Section 2[/goto]
[goto=testanchor3]Section 3[/goto]
[/list]
[anchor=testanchor1]Heading for section 1...[/anchor]
Lorem ipsum ... etcetera ...
[goto=contents]Return to Contents[/goto]
[anchor=testanchor2]Heading for section 2...[/anchor]
[anchor=testanchor3]Heading for section 3...[/anchor]
would result in:
Contents
Return to Contents
Return to Contents
Return to Contents
If all of this is complete gobbledegook, please just ignore it :)
maz_r
Binary Bodger
Re: Anchors and gotos
Postby dapinky » Sun 21.05.2017, 16:07
Ahh, hyperlinks for techy geeks....... (I understand it :shock: )
Postby muley » Mon 22.05.2017, 08:46
maz_r wrote:A feature has been added that allows you to put 'sub-sections' within a post such that you can add clickable links into a long post.
Code: Select all
[list]
[/list]
would result in:
Contents
Return to Contents
Return to Contents
Return to Contents
Done.
1995 Palacio S2 no 507
Postby clemo » Mon 22.05.2017, 10:04
dapinky wrote:Ahh, hyperlinks for techy geeks....... (I understand it :shock: )
I best stay well away then.
Jim Clark S2 - 1/13. The one with the Yellow spoke wheels . No 613 on dash (pushed in to factory in wrong order 615 on tub)
clemo
Return to New User Help with Postings and Extras
