LEC club stand / tickets
For sorting out travel plans, meetings etc.
Re: LEC club stand / tickets
Postby theelanman » Thu 27.09.2018, 20:46
If anyone has a couple of spare tickets and a car pass that is for the standard parking I would like them for one of our local club members who has left it until the last minute to decide that he is coming
he will be coming in a 1969 Elan S4 so would be allowed to park on site provided he has the right pass
anything would be good
I shall be at Dunston Hall from about 3pm tomorrow
cheers
Gareth
Postby GeoffSmith » Thu 27.09.2018, 20:52
Ask Trevor on FaecesBook. He's just passed on the green pass to Henri Van Gelder so Henri should have a yellow pass.
Postby dapinky » Thu 27.09.2018, 20:52
John_W wrote:The car is currently in the garage until I feel like looking at what is wrong. I will then post on another thread for advice on how to fix it (it's not cables or anything external, it's something more expensive). Shame - it's the first time it's let me down (not counting potholes on Skye).
John,
Sorry to hear your woes - and I hope it's nowt too expensive.....
.... i know you said that you only have 5th - but is it jammed in gear, or that is the only one that you can select?
Either way, it's unlikely to be cables (as they will *normally* allow some variation of gear, either 1,3,5 or 2,4,R if it's one cable, and then 1,2 or 3,4 or 5,R if it's the other one).
If it's jammed in gear, then I would suspect that the indent cam in the selector housing has become lose (a common-ish fault which means that the bit which stops you going into reverse whilst going forward moves on the shaft and stops it coming out of 5th gear.... easy repair - and free!) - otherwise it could be the big nut on the end of the gear shaft - again a free repair......
..... any more than that may not be so quick and easy (and cheap) to fix as it could be anything inside the box of cogs causing the problem.
Good luck with the search and remedy - you'll be missed - but probably a sensible move to limp home as opposed to me having to get my spanners out in a dusty carpark......... again!
Postby JusNoGood » Thu 27.09.2018, 21:16
TrevorB wrote:HAVE TWO GREEN PASSES AND ENTRY TICKETS AVAILABLE
Anyone that can make Dunston Hall for the convoy on Saturday morning there yours.
First come and all that.
Trevor
:cheers:
Hi Trevor, If I can reserve one of those I'll definitely come in IB10. :D
JusNoGood
Postby John_W » Thu 27.09.2018, 21:28
Pinky,
It’s definitely not the linkage or anything “external” (I checked that at Stirling before making the decision to turn back). Your other two suggestions are exactly what I was thinking (I mean hoping for). It’s not jammed in gear, but getting it out doesn’t feel nice at all.
Thanks for the good wishes. (By the way, I’ve sent Clemo an email about the jig for the roll bars, and BigErch has the shortbread, rowies - don’t let Geoff near them as he’s already had one heart attack - and extra teabags).
Have a great time.
Postby GeoffSmith » Thu 27.09.2018, 21:34
John_W wrote:…BigErch has the shortbread, rowies…
Not the best of backup plans. :lol:
Postby John_W » Thu 27.09.2018, 21:42
The best I could do at the time, given that Stevo has defected to TVRs.
:lol:
Postby TrevorB » Thu 27.09.2018, 22:13
Trevor
:cheers:
PM sent
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby Tuga2112 » Thu 27.09.2018, 22:59
dapinky wrote:.... i know you said that you only have 5th - but is it jammed in gear, or that is the only one that you can select?
note one thing, if the sideways motion cable broke while in 5 gear, due to the "6th gear protection" design of the geabox, you would be effectively stuck in 5 forever, because your unable to move the lever back to the centre position.
John, please triple check that, i have a spare (albeit 27 years old) sideways motion cable in working condition when the other cable broke last year while i was driving to work and i managed to (very luckily) get my hands on the refurbished S2 cables from henk-jan for a fraction of the only known reliable alternative (bcn short shifters)
just send me a PM if you confirm that is your problem. (for some reason the forum stopped allerting new replies to subscribed threads again for me)
Postby Brit-Car-Nut » Thu 27.09.2018, 23:07
That is not true. The Crossgate is spring loaded and it defaults to the 3rd/4th slot.
There are several problems that can lock the gearbox in 5th gear, but the most common is the nut on the 5th gear shaft coming loose.
http://forum.lotuselancentral.com/viewt ... 80#p191268
It is a LONG topic and more common than most.
Postby Dave Eds » Fri 28.09.2018, 00:54
Trevor
I'll find you :-D
Postby TrevorB » Fri 28.09.2018, 09:38
Update of list as of this morning before leaving:
1. Trevor B
2. Dapinky
3. Alan E
4. Kathryn
5. Rice crispy
6. Chris P
7. Clemo
8. Spud
9. El abuelo (Geoff)
10. SimonW
11. Steve A
12. Tuga2112 (Joao)
13. LFM (Phil)
14. Readit (Ken)
15. Roy666 (Mike)
16. Peter Hill
17. Simon_P
18. TB10 (John)
19. Justin (JustNoGood) (Now with RED pass as will be coming in IB10 the project car which is original)
20. Gareth Flanagan (awaiting confirmation)
See you all tomorrow and some of you tonight. Safe journey everyone.
Trevor
:cheers:
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby John_W » Fri 28.09.2018, 09:54
João, John,
Thanks for the suggestions. Brit-Car-Nut got it in one. Thanks for the thread link. The first post by Valimar exactly describes what happened to me yesterday. I will read and digest and continue this conversation on that thread.
Postby JusNoGood » Fri 28.09.2018, 11:11
TrevorB wrote:Update of list as of this morning before leaving:
1. Trevor B
2. Dapinky
3. Alan E
4. Kathryn
5. Rice crispy
6. Chris P
7. Clemo
8. Spud
10. SimonW
11. Steve A
12. Tuga2112 (Joao)
13. LFM (Phil)
14. Readit (Ken)
15. Roy666 (Mike)
16. Peter Hill
17. Simon_P
18. TB10 (John)
Trevor
:cheers:
Uh oh the word original...I can easily remove my wind deflector if it's not appropriate...I do want it for my journey though :-D :lol:
JusNoGood
Postby Steve A » Fri 28.09.2018, 11:28
You have a pm Trev :poke:
Postby Dave Eds » Sat 29.09.2018, 07:21
I'm not going to make it there in time to claim my pass and tickets from Trevor, so if anyone else wants to be on the LEC display then go for it.
Reverting to plan B now :roll:
Return to Hethel 2018
