For sorting out travel plans, meetings etc.
by GeoffSmith » Sun 30.09.2018, 19:57
… is home:
PS There is a prize of one bag of Tesco doughnuts for the person who correctly identifies what was used to effect a temporary repair to the offside light.
PPS And yes, Clemo and I drove past a truck on the M4 carrying a giant haystack.
PPPS another picture tomorrow when the camera battery is charged.
- Kitty Fiddler
by clemo » Sun 30.09.2018, 20:10
Well I can correctly identify how the leak was fixed.
For a further 10 points can anyone correctly identify which muppet locked his keys in his boot!
Great LEC weekender again all.
See you all at the next one
clemo
- LEC Administrator
- Location: TORQUAY Devon. Cream first then Jam obviously.
by alan e » Sun 30.09.2018, 20:18
Did you have no more leaks after you turned off to Newmarket, i mean the car not you having a leak.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
by GeoffSmith » Sun 30.09.2018, 20:18
clemo wrote:Well I can correctly identify how the leak was fixed.
Oh no you can't, the picture is in front of my house and it hasn't been fixed yet. It's not the exploding pipe that nearly gave Alan a heart attack at Mildenhall services 6 hours earlier!
- Kitty Fiddler
by GeoffSmith » Sun 30.09.2018, 20:19
alan e wrote:Did you have no more leaks after you turned off to Newmarket, i mean the car not you having a leak.
Only in front of my house when I got home Alan. Hope you made it back safely and thanks for waiting.
- Kitty Fiddler
by alan e » Sun 30.09.2018, 20:24
Yes i got home with no problem hope you find the leak and you can fix it
2010 black evora
MG ZS EV
alan e
by GeoffSmith » Sun 30.09.2018, 20:24
Looks like bottom rad hose - set of Samcos should do it.
- Kitty Fiddler
by alan e » Sun 30.09.2018, 20:26
GeoffSmith wrote:Looks like bottom rad hose - set of Samcos should do it.
2010 black evora
MG ZS EV
alan e
by Dave Eds » Mon 01.10.2018, 00:50
Can anyone name the LEC car thief?
by dapinky » Mon 01.10.2018, 10:48
Yeah, but after all the 'experts' had got the keys back for the Muppet (using tools from wherever they could be borrowed)...
... who was left with the job of putting it all back together again (and getting the panel gaps to the Muppets' satisfaction
- LEC Administrator
by GeoffSmith » Mon 01.10.2018, 11:41
This is probably a stupid question, but why did you take the boot off Clemo's car?
- Kitty Fiddler
by Dave Eds » Mon 01.10.2018, 11:54
To make it easier to put the lock back together apparently. Or just because he could
by GeoffSmith » Mon 01.10.2018, 12:00
Ahhh! When I took my lock off in the garage to have a look at it, I just rested the U plate in the right position and carefully inserted the screws while lying across the boot.
- Kitty Fiddler
by Giniw » Mon 01.10.2018, 13:42
GeoffSmith wrote:clemo wrote:Well I can correctly identify how the leak was fixed.
Oh no you can't, the picture is in front of my house and it hasn't been fixed yet. It's not the exploding pipe that nearly gave lan a heart attack at Mildenhall services 6 hours earlier!
Oh shucks, I gather one of you had a spare one?! And coolant too?
Giniw
by dapinky » Mon 01.10.2018, 15:09
GeoffSmith wrote:Ahhh! When I took my lock off in the garage to have a look at it, I just rested the U plate in the right position and carefully inserted the screws while lying across the boot.
If I'd been the one to take it apart, it would have been far easier.... but by the time I looked at the job, there were a handfull of parts which no-one could work out the right way to put together. The metal plate between the bootlid and U clip was detached and wouldn't stay in place to line it all up without an anti-gravity device, so removal was the easiest option.
- LEC Administrator
by Tuga2112 » Mon 01.10.2018, 21:40
GeoffSmith wrote:… is home:
looks like a side effect of not driving it often enough to me...
by Rice crispy » Sat 06.10.2018, 21:21
I had a brand new bottom hose in the boot if I had known you could have had it
Rice crispy
by John_W » Sat 06.10.2018, 21:47
Nah... wouldn’t have helped me.
- Heid-bummer
by Rambo » Sun 07.10.2018, 08:17
John_W wrote:I must be catching some of Geoff's luck. Look where I found the missing tooth from my 5th gear.
It was in the oil lubrication gutter in the 5th gear compartment. So I don't have to take the gearbox apart to find it!
Did you get a £1 coin left under your pillow from the geartooth fairy
- Don't push me
Return to Hethel 2018
