What's this...
Share your pictures!
Re: What's this...
Postby muley » Tue 09.11.2010, 17:57
Specky wrote:First Generation AB cable spanners.
Electric coolant motor pump bracket YES
PAS pipe NO
Parts cat YES
and the piece of metal seems familiar, but I can't place it...
1995 Palacio S2 no 507
Re: What's this...
Postby muley » Tue 09.11.2010, 17:59
Brit-Car-Nut wrote:A multiple part test!
Wrenches for the AB shift cables YES
Power Steering hose from oil tank to pump end? NO
A/C hose? the V implies it gets aligned somewhere. But you're right this time it is part of an A/C hose
The clamp / alignment bracket? I don't know.
Re: What's this...
Postby Specky » Tue 09.11.2010, 17:59
Oil cooler pipe then
Re: What's this...
Postby muley » Tue 09.11.2010, 18:00
See above
We're just left with the bracket..
Re: What's this...
Postby Specky » Tue 09.11.2010, 18:02
Page before
Re: What's this...
Postby muley » Tue 09.11.2010, 18:03
Specky wrote:Is it the gearbox tag that sticks up and catches your bloody arm
Well done! It was a rubbish picture, too. I've done about 8,000 miles without it so I'm convinced it's not important :)
Re: What's this...
Postby Specky » Tue 09.11.2010, 18:05
Add lightness... Bet you've thrown the weight distribution out now...
Re: What's this...
Postby lotusdriver » Tue 09.11.2010, 18:12
Two pages from the 1995 issue of the spare parts list
Two gear cable spanners
Part of the hose from the aircon condenser to the lower port on the aircon compressor
The bracket for mounting the boost control solenoid valve to the metal bracket fixing the air cleaner housing to the longeron
An unused bracket designed to randomly injure. It's fitted to the upper edge of the gearbox casing above the LH inner tripod joint and just outboard of the gear cable ends
Edit
Bugger I'm too late!
Is that really the coolant pump bracket?
See 46.01 in the parts book Item 62.
lotusdriver
Re: What's this...
Postby muley » Tue 09.11.2010, 20:02
Good work, I was being cheeky with the coolant pump bracket it IS a coolant pump bracket but for a Jabsco pump ex-Us. The standard one is normally bzp finish..
Re: What's this...
Postby Specky » Thu 11.11.2010, 14:46
Lets seperate the men from the boys..... :twisted:
Sorry it's photobucket again...
Here's 4 Items, what are they and where do they live...
Re: What's this...
Postby steve matthews » Thu 11.11.2010, 15:42
Specky wrote:Lets seperate the men from the boys..... :twisted:
Hood stowage lid release cables
Gas breather @ gas tank
Rear stabilizer bar
Heated seat controler????????
Steve
steve matthews
Re: What's this...
Postby Specky » Thu 11.11.2010, 15:58
Hood stowage lid release cables (Yes, Preproduction or prototype, the hood cover is side locking, not the central two points)
Gas breather @ gas tank.... yep
Rear stabilizer bar... No
Heated seat controler????????... Ummmmm... yes it is, but why's it quirky or where is it fitted as standard ?
Re: What's this...
Postby bobbrown » Thu 11.11.2010, 16:34
bottom picture
bonnet stay?
alarm indicator?
Pacific Blue N/A
Re: What's this...
Postby Specky » Thu 11.11.2010, 16:46
bobbrown wrote:bottom picture
bonnet stay?
alarm indicator?
Bonnet stay...yep... the crap varient before they changed it...
Alarm Indicator... nope... I like the lateral thinking...
I'll give a clue as it's a bit cheeky... :-D It's a heated seat switch... (That bits correct and not very hard to work out :lol: ) But where does it live..........
1st clue... when the car was blue, it didn't have them fitted.
Re: What's this...
Postby steve matthews » Thu 11.11.2010, 16:55
bonnet stay?
alarm indicator?
1st clue... when the car was blue it didn't have them fitted.
The cotter pin gives it away now.
It's black and box shaped how about on the center console
several empty spaces.
Steve
steve matthews
Re: What's this...
Postby Specky » Thu 11.11.2010, 16:58
It doesn't go on the centre console...
2nd clue
The blue car is now yellow..... and I think the AA got called out to this car... :lol:
Re: What's this...
Postby Brit-Car-Nut » Thu 11.11.2010, 17:02
Actually that is the Roll-Over Valve. It is in the vent line to prevent fuel from leaking if the car overturns.
It is very interesting to see the differences in the SE between the prototypes and the FED version.
HD Replacement Shift Cables and Short Shift Kits still available
HD Replacement Shift Cable and Short-Shift Kit prices
Download Manuals Here
Re: What's this...
Postby Specky » Thu 11.11.2010, 17:08
I thought you had got the Link
Prototype....
Preproduction...
N/A
SE
S2
and then............ :D
There's one more Elan...
Re: What's this...
Postby Specky » Thu 11.11.2010, 17:30
Brit-Car-Nut wrote:Gas breather @ gas tank.... yep
and when the car's the right way up it's a....... :lol:
Re: What's this...
Postby Brit-Car-Nut » Thu 11.11.2010, 17:44
It is part of the vent line that goes from the tank to the charcoal canister. It is NOT a vent. If the vent line went directly to the canister and the car overturned, the fuel would empty into the cockpit which is not desirable. The Roll-Over Valve is designed to shut off so nothing can get past it if it isn't right side up.
Return to Picture Gallery
Users browsing this forum: Google [Bot] and 1 guest
