Share your pictures!
by Michael » Tue 29.05.2007, 18:30
Today, this is this is what mine lookes like after 81.500km/51.000mls
Former Elan owner
Michael
by dapinky » Tue 29.05.2007, 19:33
132K miles (and it shows if you look at the grotty bits!)
It's an ongoing project
- LEC Administrator
by Enright » Tue 29.05.2007, 20:19
Here's mine. And I'm on just over 93,800 miles.
Neil
- Modificator
by Dave Eds » Tue 29.05.2007, 20:39
Bet that wern't taken on Sunday Neil
by Enright » Tue 29.05.2007, 21:06
Damn right! It was taken an hour ago. There was no way I was going to open my bonnet on Sunday - I'd already got enough water in my footwells thank you! They're still full of newspapers...
Neil
- Modificator
by ailwyn » Tue 29.05.2007, 21:18
Neil,
Is your O2 sensor cable secure there? Mine was left off by a garage and was resting on one of the belts
Fortunately I found it before it chewed through the wires (although it did a good job on the cover for the wires)!
A.
- Forum Member
by Doug » Tue 29.05.2007, 21:25
good eye, Ailwyn! Neil you should move the electrical connector junction to the other side of the headlight motor -- there's a little hole in the headlight mount that the connector is supposed to plug into as well to secure it there (I can just see that on your picture).
- LEC Founder
by tigerdog » Tue 29.05.2007, 21:41
I sense a pattern involving the grinding/removal of "Isuzu" and body colour valve covers. Very pretty!
by Dave Eds » Tue 29.05.2007, 21:50
tigerdog wrote:I sense a pattern involving the grinding/removal of "Isuzu" and body colour valve covers. Very pretty!
And Brian's oil filler caps
by Enright » Tue 29.05.2007, 23:12
Thanks Ailwyn and Doug.
I did wonder about that when installing it.
I was confident that the wire couldn't snag on any moving parts, but have now moved it as per your recommendation, and have to admit that it's a lot neater.
Tigerdog, if you're going to go down that route, then it's just as important to remove the two surplus lugs on the LHS of the oil filler cap and on the RHS of the "LOTUS" (and to fill the remaining holes).
Neil
- Modificator
by tigerdog » Wed 30.05.2007, 01:21
Enright13 wrote:Tigerdog, if you're going to go down that route, then it's just as important to remove the two surplus lugs on the LHS of the oil filler cap and on the RHS of the "LOTUS" (and to fill the remaining holes).
Thanks, Neil! Actually, my first task will be to acquire an Elan. Then the fun can begin.
by lotusgirlmarie » Thu 31.05.2007, 17:39
New turbo to be going in July of this year.
lotusgirlmarie
- Goddess
by Ichiroh » Thu 31.05.2007, 19:46
My ELAN's motor compartment is empty(ToT)
Ichiroh
- Tinkerer
by johnny » Thu 31.05.2007, 19:59
And all Frank Spencer wanted to do was change his air filter.
Hey- there's only on f in Geof Smith.. U crack me up. Poor old Dad..
johnny
by Paul.P » Thu 31.05.2007, 21:10
Here's mine, more plating to be done over next winter !
by Yellow Sexy Lotus » Thu 31.05.2007, 23:09
Heres mine 110K....avatar will be posted soon as the rain stops and I can get it out
Yellow Lotus Elan SE Turbo
Yellow Sexy Lotus
by Monty » Thu 31.05.2007, 23:20
Like to keep mine as standard too
Actually the cam cover is slightly different colour now
- Chunder King!
by Yellow Sexy Lotus » Fri 01.06.2007, 00:04
Guys, I can't see your pitures (Monty, Paul.P, LotusGirlMarie others!)
But I can see Micheal and Ichiroh's images??? What host sites are you using or is it just that I don't have privalige/enough posts
Yellow Sexy Lotus
by GeoffSmith » Fri 01.06.2007, 00:06
Yellow Sexy Lotus wrote:or is it just that I don't have privalige/enough posts
Are you sure you're logged in?
- Kitty Fiddler
by Yellow Sexy Lotus » Fri 01.06.2007, 00:08
Yep! Think so!
I can post, see my pictures and also log out
Yellow Sexy Lotus
Return to Picture Gallery
