R.I.P. - Pinky
Re:    R.I.P. - Pinky
Postby ESM » Wed 16.03.2005, 12:19
[quote author=_Monty_ link=board=nontechgen;num=1107619750;start=135#139 date=03/15/05 at 16:14:59]...Theres only one thing there`s a winding noise , think it`s coming from the front,...[/quote]<br>Could be the alternator belt or the alternator itself. Check the belt tension first. Consider the rear wheel bearings as well, it can be difficult to tell where bearing noise is actually coming from.
ESM
Re:    R.I.P. - Pinky
Postby muley » Wed 16.03.2005, 12:34
Monty,<br><br>Good news, see you at Donny m8. I hope Adam gets over the mugging quickly.<br><br>Jim B
Re:    R.I.P. - Pinky
Postby rob » Wed 16.03.2005, 12:47
Following on from what Alan has said..........<br><br>I had my timing belt change a couple of months ago and the muppetts tightend it up too tight. It was ok when cold but when the engine heated up the whining started, so I put a gag in Rach's mouth but the whining was still there.<br><br>Took it back to them and they loosend it off, all is now well.<br><br>Just a thought as you have 68k on the clock so it must have had a cam belt latley.
rob
Re:    R.I.P. - Pinky
Postby nchase » Wed 16.03.2005, 13:04
Well done Monty - don't suppose you took a visit via that well known brake specialist......Hi... somthing or other - they are in Dartford.... and hey why didn't you let me know, I am 20 mins drive from there.<br><br>See you Fri/Sat.<br><br>
nchase
Re:    R.I.P. - Pinky
Postby Monty » Wed 16.03.2005, 17:22
Thanks guys for u`r kind words, its a bloody good car just a shame about the winding, it only does this on the move so can`t see it being a belt. I`m worried about driving it, if i get time tomo`s i`ll take it to the local garage and get it up on the ramp, wheels of ground and run the car to see were the noise is coming from.<br><br>nchase,<br>I didn`t have time to soicalise, as i went in dico`s truck and he was pushed for time on his little tacho LMAO  ;D<br><br>See u all at Donny.<br><br>
Re:    R.I.P. - Pinky
Postby mark29 » Wed 16.03.2005, 17:25
nice one monty, hope you get twice the enjoyment out of pinky II than you did from pinky I (RIP)<br><br> ;)
1992 silk red se turbo...
mark29
Postby Monty » Tue 09.08.2005, 19:46
Took me a while to find this thread. :roll:
Well it`s been a long time since i started the engine in Pinky 1, had to join the oil cooler pipes together, stick some oil in her and put the garden hose in the expansion tank as the raditator was kinda leaking :roll:. Can`t believe it she started 1st time and no check engine light and sound better than pinky II, so i`ve recorded the engine running on the camera just incase i ever sell the engine.
I have now dropped the engine and box and stripped the front. here`s a few pic`s.
Postby John_W » Thu 15.09.2005, 12:14
Wow. Looks like a big job.
Good luck with it,
Postby TStevens » Fri 16.09.2005, 15:13
Monty, Stage one completed, I've 'found' the thread and got it visible again, I now need to fix the pagination.
TStevens
Postby Monty » Fri 16.09.2005, 19:00
Thanks Tony what would we do with out u. :D
John thats not going back on the road, it`s being stripped.
Postby Monty » Mon 10.10.2005, 17:12
Couple of pic`s off damage to pinkys bulk head :cry:
Postby Monty » Sat 29.10.2005, 15:53
For the attention of jack.
Pinky`s steering wheel.
Postby Monty » Fri 08.02.2008, 22:58
Well it`s just been over 3 years since the lost of Pinky :cry: so it`s about time i gave this rusty relic a sending off. Started cutting the body in half, next step is to have it 4 pieces and off to the dump she will go.
Postby Dico » Fri 08.02.2008, 23:42
Thems my barbecue bricks propping the pink wreck up :?
I think you should cremate it. Sod the neighbours :twisted:
Postby Sy V » Sat 09.02.2008, 18:24
Jay
I'd take the rear panel fastener uprights of first mate (if they're intact - they look it).
Postby Monty » Sat 09.02.2008, 18:47
Sy V wrote:Jay
Sy, which rear fastners do you mean?
Mine you it`s to late now as most of Pinky is now at the rubbish tip :roll: Just got 2 pieces to dump and that`ll be the end of her :cry: So Dico and I have been busy today.
Postby Doug » Sat 09.02.2008, 19:39
sad :(
you can't make a kitchen table out of the chassis?
Postby Sy V » Sat 09.02.2008, 19:47
... too late, I meant the two grey pillars with clips that the hood cover deck fastens on to.
Postby RayD » Sat 09.02.2008, 20:50
Jay,
Which of the bits are steel on the sills?
Postby Monty » Sat 09.02.2008, 21:03
The part where the holes are is metal which is shaped like this ] so goes top and bottom but not on the impact side :? #4 is not metal. There`s also a couple of layers of Fiberglass.
Neve checked #3 but i think that is metal as thats for the seat mounts.
Return to General
