Elan vs Elise
Elan vs Elise
Postby Benmac » Thu 08.02.2007, 16:48
Right, now I've owned the Elan for a little while I feel in a position to judge. OK, both cars have their fervent and sometimes (naming no names) blinkered supporters. I like to count myself in both camps with no bias either way. They’re very different but equally very similar. Vive la difference, perhaps. I count myself very fortunate to be able to have both in my garage though.
I’ve owned two Elises, both S2s and have driven a number of others and derivatives (S1s, Exiges, VXs). As such my Elise experience is greater than my Elan experience which is limited to my car, and a couple of others. Its probably worth explaining a little about my particular cars for the purposes of any comparison. Firstly the Elise. My car is one of the 30 or so S2 Sport 190s produced by Lotus Motorsport during 2002 and 2003. As such its not a common or garden S2. The key difference is of course the VHPD K series. The engines for the S2 190s are different animals to those found in the S1 version and the S1 Exige and 340R. As opposed to the earlier cars the S2 engines were built in house as more personnel were available in the motorsport department now that they weren’t needed to build and maintain cars for the Motorsport Elise championship. There are various detail differences in the engine’s spec but the key thing to note is that they actually do reliably make the claimed 190bhp! Mine was bench tested at 196bhp as it happens. The 190s were built by Motorsport after being pre registered and taken off the end of the normal Hethel line. The other modifications of note include adjustable sports suspension, OZ superturismo wheels with Yokohama A048s, 340R seats and 4 point harnesses. There are myriad other detail changes under the skin from a normal car and the 190 option list went as far as battery cut off switches, roll cages and fire extinguishers. My car is definitely road orientated with the standard spec of the engine, suspension and wheels and the addition of the 340R sourced seats. The only modifications to my car from this spec include the removable steering wheel, an Eliseparts gear linkage kit and quickshifter and a sports catalyst.
My Elan also has an interesting provenance in that it was a pre production car used for some of the last bits of durability testing. As a result it has a few details here and there that are different, extra sound proofing, the odd bit made of metal rather than plastic, nothing significant. Other than that it’s a pretty standard SE. Its obviously pretty old now so it does now benefit from S2 wishbones and dampers all round, a big brake conversion an S2 roof and a stainless steel exhaust.
So how do they compare? Well this is where it gets tricky. Notwithstanding age issues (I don’t drive the Elan with the same ‘ahem’ vigour’ as I do the Elise) it is a case of ‘horses for courses’; however take one and put it in the other’s element and neither would fall at the first hurdle. If it’s a long distance run involving motorways and traffic my hand would instinctively reach for the keys to the Elan, whilst for a trackday it has to be the Elise. That is however something to do with why I bought both of them. Both are fun, both reward, both feel special in that way that Lotuses do. I may get to the other end of my long journey with bleeding ears and a sore back in the Elise but I’ll be smiling (of course other Elises might be better at that than mine) and on track in the Elan (were I to try it) I may not be keeping up with the ‘semi slick’ shod Exiges and 911s but I know I’d be having fun.
I’m not going to discuss the nuances of where grip ebbs away in one and how each communicates to you on the limit as those sorts of details can be found elsewhere. To me the key differences in their driving performance relates to which wheels are driven and the nature of the engine. The Elan is FWD and powered by a turbo motor. Both these aspects make themselves plainly obvious. Some may take that as a criticism but to me it is anything but and only reminds me of what Lotus achieved with the car. The turbo may not be the last word in minimal lag etc but I’ll take the ‘slight pause, wooosh, change gear, flutter of the wastegate then off again’ delivery over the anodyne wall of torque power delivery of some more modern turbos anyday. It is part of the car’s character and all the better for it. You feel the push that lump precariously placed at the front of the engine bay gives you and it makes you smile, simple end of. Ah, now we’re onto the FWD issue. ‘Oh heaven forbid a FWD sports car, how wrong can it be?’ was the general wailing and hand wringing from many when the Elan arrived and arguably the relative lack of success could be attributed to people having some notion that they simply must be able to hang the tail out on every corner on the way to work. Has that ever been the raison d’etre of a Lotus though? In my opinion definitely not, swift assured, communicative and precise progress is what they’re all about and this the Elan can do with utter ease. You pull away hard and you can feel the wheel tug a little but then you’re up to speed and attack a few bends and instantly which end is driven becomes immaterial as the thing just flows, it goes where you want it to and the package of steering and throttle sensitivity help you get the attitude just right. Give me a well set up FWD car than a badly set up RWD car anyday.
Onto the Elise then and onto that ‘same but different’ issue again. Does the Elise respond well to aggressive inputs, hurling it into bends and sorting it out later? No. Does the Elise ‘breathe’ down the road in the same way as the Elan? Yes. Does the Elise tell you what is going on at each wheel all the time? Yes. Does the Elise feel the same as the Elan? No. The difference is simply though the difference between a mid engined RWD car and a front engined FWD, there would be something wrong if they felt the same. You know the weight is behind you in the Elise and that the cornering attitude taken must seek to balance this just as you know the Elan is FWD as you feel the wheels taking up the power through the steering. Not faults just characteristics of what the cars are. Neither is lacking through having more or less of any such aspect.
To conclude then it is as I said previously, Vive la difference. People can argue about which is better from here to kingdom come (usually Elise owners, I’ve never understood that particular insecurity and need to positively compare the Elise with everything from a Clio to an Enzo) but I’ll leave them to it. Put an average driver in each of them though and ask them to go as quickly as possible down a wet, twisty, dark road and I’d put my money on the Elan. Does that make it less of a ‘drivers car’ (whatever that may mean??). Absolutely not.
Frost Silver Elan SE
Starlight Black S2 Exige 240Cup
Benmac
Postby Doug » Thu 08.02.2007, 19:56
Thanks -- nothing like an "informed" comparison. Certainly they are different cars, from a different generation of design too-- but both from Lotus!
I'm thinking you'll like the Elan more with an ESM chip and more boost for free.
Happy motoring :-D
Postby Monty » Thu 08.02.2007, 20:09
Good write up Ben,
Let me know when u next visit the track wouldn`t mind a pax ride in the 190 :-D
Postby clemo » Thu 08.02.2007, 21:40
thank you ben.
clemo
Postby Don.Hasi » Thu 08.02.2007, 23:29
good posting, Ben :)
As you already know, I have two bastards :-D and they have both their own gaming zone.
as I have now a new setup, or to say it clear, the first time a right setup, I´m interested how it will work in summer with the right wheels on it. From corneringspeed they will be faster than much others on the road, but we will see.
But Ben, a 190sport N/A comparing with a turbo :smt018 :roll: :wink:
Kind regards
Don.Hasi
Postby Ekapol » Fri 09.02.2007, 00:49
:goodposting: Thank you Ben. I look forward to reading more of other aspects comparison. Reliability, services, etc.
Elise is a really nice looking car but there is something in Elan's design line that makes me happy every time I turn head looking back at her.
Ekapol
Postby Mike » Fri 09.02.2007, 02:48
Per Doc Bundy, he of IMSA-winning X180R fame- everytime he introduced the pre-production Elan in '91 to the American dealers, most could not believe it was not a mid-engine layout due to the neutral handling. Doc continues to be very effusive in his praise of the Elan 15 years later.
Interesting write-up as it reminds me of another Elise/Elan owner's comments that are spot-on to yours. Since you don't have a dog in the hunt for either car, I would think those on both sides of the issue would find your opinions most believable when compared to all the vitriolic postings on Elisetalk
Mike
Postby cjay » Fri 09.02.2007, 12:39
Good post Ben
I had :( an Elan and now have an Elise. Both S2's The main difference I found was the Elan made me giggle like a school girl when i drove it and the Elise just makes me grin, it hard to explain but the Elan just had "it"
Another difference was that I was reasonably healthy when I had the Elan, not long after getting the Elise I discovered I was going deaf, had 4 bulging disks in my neck and back and 3 of my fillings have fallen out... might be why I only grin not giggle in the Elise :-D
I wonder what color the next one will be?
cjay
S2 #475
Postby charliex » Sat 10.02.2007, 21:59
I have an m100 for a long time, had a few elises over the years, now got the exige, and the S on the way.
I really like driving my elan, its smooth, handles great and is a lot more forgiving especially here, the exige is a handful on the roads here it breaks traction on almost every corner ( our roads suck ) luckily the traction control takes care of it.
even though my m100 is boostless at the moment, i still drive it around and leave the exige in the garage, partly due to the akwardness of the exige around town, although if i'm going anywhere with crazy speed bumps i don't take my m100 since i can't get over them!
trackwise they're both a lot of fun, i've lent my m100 out a few times to elise owners at various events and they're usually suprised by how well it handles, m100 handles great no drama, good boost kick, exige generally makes me feel like i have to be 100% concentration all the time.
of course when my m100 is running normally it gives the elise a run for its money :) it does suffer from torque steer (when its working) but otherwise the handling is just great.
i'm pretty sure the S will give the m100 a hard time though, at least it better, but its limited in its current design, can't really beat a turbo charger for power, although with the torque steer i'm probably limited in how much mroe power i can put down.
I have the base exige with lsd,tc , ac delete, so its a lot more 'raw' than a sports pack equipped model, the S i drove at the lotus press day was super smooth and felt a lot more like the m100 in terms of drama, which may not necessarily be a good thing.
i've driven both on 1000+ mile journeys, and i'm ok with either, the elan is a lot more comfortable , but exige is fine with earplugs, but i'd probably choose the m100 if it came to it for that.
my m100 has 74,000 miles, the exige only 4000 and i've had it a year :)
the exige is uma thurman, the m100 marilyn monroe.
charliex
Postby Ekapol » Sun 11.02.2007, 05:22
charliex wrote:the exige is uma thurman, the m100 marilyn monroe.
:goodposting: That says it all. And the Exige S is ....
Ekapol
Postby Scott J » Tue 13.02.2007, 16:15
Interesting write ups, keep it coming
Scott J
The prodigal son
Postby Doug » Tue 13.02.2007, 19:09
Ekapol wrote:And the Exige S is ....
Carmen Electra ??
Postby charliex » Sun 13.05.2007, 23:30
Well i just upgraded to an Exige S a few weeks ago, i'm not entirely sure what it is yet.
charliex
Return to General
