Ypres Lotusday 2013 !
Re: Ypres Lotusday 2013 !
Postby Fredjohn » Fri 17.05.2013, 11:49
paulsmithmk wrote:may be privacy settings on folder in photobucket?
Thanks Paul. Changed setting reloaded photos and they should be visible now.
But can't get them as big as everyone else's..... :?: :?: :?:
Postby paulsmithmk » Fri 17.05.2013, 12:03
mmm not sure on size but also they cant be clicked to go to your library - did you copy and paste the IMG link in photobucket?
S2 Number 640
paulsmithmk
Postby Steve A » Fri 17.05.2013, 12:12
:D Working now :smt023
Postby Fredjohn » Fri 17.05.2013, 12:50
paulsmithmk wrote:mmm not sure on size but also they cant be clicked to go to your library - did you copy and paste the IMG link in photobucket?
CRACKED IT :-D :-D :-D Now you can view them properly
Postby paulsmithmk » Fri 17.05.2013, 13:38
:cheers:
S2 Number 640
paulsmithmk
Postby Steve A » Fri 17.05.2013, 13:49
Now I'm only seeing the first image now :?
Postby paulsmithmk » Fri 17.05.2013, 14:18
I see them all...
S2 Number 640
paulsmithmk
Postby chris.t » Sat 18.05.2013, 08:31
Works fine for me, good photos and vids guys.
Postby Steve A » Sat 18.05.2013, 09:33
Full house :D
good snaps and videos all round :cheers:
wish I'd done a video now :cry:
Postby Rob P » Sat 18.05.2013, 10:22
excellent snaps and super videos there guys, the more I see the more I feel this is a trip to make next year, :burnout:
simplify and add lightness
1997 Lotus Elise S1 - Metallic Racing Green
Rob P
Postby paulsmithmk » Sat 18.05.2013, 13:08
S2 Number 640
paulsmithmk
Postby chris.t » Sat 18.05.2013, 18:36
paulsmithmk wrote:how we think we drove!
https://www.youtube.com/watch?v=NS0H6xJ5xK8
Errrrr very nearly and then Deirdre started swearing at me.
Postby paulsmithmk » Sat 18.05.2013, 20:19
ha ha!! I couldn't cut the corners like that but am attempting to raise the suspension tomorrow....
S2 Number 640
paulsmithmk
Postby paulsmithmk » Sun 19.05.2013, 14:20
Looks like I only just got away with things... going to get this checked out and I could only raise rear suspension it needs to go somewhere better equipped anyway..
S2 Number 640
paulsmithmk
Postby Steve A » Sun 19.05.2013, 16:49
Ouch :!:
That gives you a dilemma :?
Is the sump lower that the exhaust ?
I had a "bash plate" welded to my westfield sump because the ride height was perfect 99.9% of the time, and I didn't want to change it for that .1%
The "bash plate" was 1/4 " thick with a nicely curved leading edge, and it took a good few hits over the years :wink:
It would be a shame if you had to take your suspension up for one day of the year :roll:
Hey John have you got any pictures of your sump :poke: aren't you running standard suspension :poke:
Postby Fredjohn » Sun 19.05.2013, 16:58
Sorry to see your sump damage Paul: not quite as bad as mine though. May be we should all slow down or raise our front suspension an inch or three.
Here's my sump well and truly split. Hoping to get it repaired at the moment: will only consider a new one if this doesn't work and if SJ can manage to persuade Lotus to get some made!!
Prongeron is off and car well supported. But how do I get those seriously well rusted studs off the exhaust :?: :?: :?:
Postby Fredjohn » Sun 19.05.2013, 17:03
Steve A wrote:Ouch :!:
Steve
Picture above :D Not sure if I have standard suspension as have GAZ shocks at least at rear, possibly also up front, and unsure of what springs I have, although rear I know are also adjustable.
My sump is lower than the exhaust, but exhaust, prongeron and sump all show signs of scrapping :cry: :cry: :(
Postby HJ2 » Sun 19.05.2013, 19:12
By the look of the underside: Your exhaust smacked on the tarmac as well.
It looks like my Ypres experience from last year. Several LEC treads on the work involved due to that...
Cracked manifold, cracked downpipe, cracked exhaust (1st bend) Damaged prongeron.... Wel... everything except the oil pan, as in my (PECO) case the exhaust was the lowest part. As you can read, this is not necessary cheaper to repair than a dented oil pan :shock:
Sorry to see your damage anyway. :(
Postby daveiow » Sun 19.05.2013, 21:20
Well gentlemen it seems I've joined the club :(
Not been near the car since returning from Ypres but after seeing Paul's pictures of his sump I've had a preliminary look and it's just like a maniac has attacked it with an angle grinder. No leaks at present and its booked in for an MOT on Thursday so will be able to give it a good going over then.
If it can wait till winter I think reinforcing with a piece of plate then some hard- facing rods may do the trick.
daveiow :m100:
"live long and prosper"
Evora n/a
Alfa Sud 1.5ti long gone!
daveiow
Postby paulsmithmk » Sun 19.05.2013, 22:16
I think it is riding low since I changed shocks and coils - I managed to raise the back today but not the front. I think a new sump will be needed if not now then soon so will do when next serviced (which is soon!) I like the idea of a plate! I also need to have a look at the flexi part of my piper - it sounds OK but again not sure from just axle stands. I loved the day but not at this cost. OK my driving had something to do with it but the roads were a foot lower on each side than the middle and that didnt help!
S2 Number 640
paulsmithmk
Return to Other Events
