M1 (South) Convoy to Donington
Re: M1 (South) Convoy to Donington
Postby rip » Fri 12.04.2013, 12:45
paulous wrote:Mobile phone networks all transmit time signal so assuming your phone is set to auto update time I'd suggest using that....
Good call. Fingers crossed that traffic doesn't spoil the plans.
Postby Steve A » Thu 18.04.2013, 16:28
For this to work I would suggest printing the list out and trying to hit the junctions at the right times, it will be all too easy to get there too early :roll: :burnout:
Postby Gazza » Thu 18.04.2013, 19:42
Me and Paul69 will be at J8 earlier than 07.29, so pull in if u get there earlier.
We can leave at correct time together
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
Postby Steve A » Thu 18.04.2013, 20:04
:? Pull in where?
I can phone Paul as we pass the juction (texting isn't an option)
all you need to do is stop him talking(not easy) :roll:
get in your cars and catch us up :burnout: :burnout: :wink:
Pulling in at every juction isn't really practical
Everyone should also make sure their fueled up, getting eleven cars together only for one to stop for petrol would be a tad silly :chair:
Postby TrevorB » Thu 18.04.2013, 20:18
Fueled up and raring to go, see you on M25 somewhere (got yr txt) :cheers:
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby daveiow » Thu 18.04.2013, 20:40
Steve,Trevor
Will phone as soon as we hit M1 , I will then adjust speed to match you
"live long and prosper"
Evora n/a
Alfa Sud 1.5ti long gone!
daveiow
Postby Gazza » Thu 18.04.2013, 23:02
Steve
Ok, give Paul a ring when u are passing. Fuelled up already, will make sure he is as well.
SOLD
Gazza
Postby rip » Fri 19.04.2013, 00:01
Steve A wrote:Pulling in at every junction isn't really practical
Shouldn't need to pull in.
I've timed most of it at a mile per minute (60mph). It may seem a tad slow but it will allow you to adjust your speed to pass each junction at the correct time without having to exceed the speed limit (unless the variables get switched on at something lower than 60 :roll: )
Postby Stef » Fri 19.04.2013, 07:40
Have set my clock to BBC and have a lay-by just before the M1 that I'll lurk in to get best timings.
Will also call RIP (as have his number) as I join, if that is ok with you RIP?
Looking forward to the event! :D
Men are like a fine wine.
Stef
TVR/PistonHeads Ambassador
Postby rip » Fri 19.04.2013, 10:05
Stef wrote:Will also call RIP (as have his number) as I join, if that is ok with you RIP?
That's fine. I have hands-free.
Postby paulsmithmk » Fri 19.04.2013, 10:45
Stef wrote:Have set my clock to BBC and have a lay-by just before the M1 that I'll lurk in to get best timings.
you should be able to hear us arriving!!
S2 Number 640
paulsmithmk
Postby Gazza » Fri 19.04.2013, 11:29
Paul
Think we will see you first before hearing you! :wink:
SOLD
Gazza
Postby paulsmithmk » Fri 19.04.2013, 11:35
Gazza wrote:Paul
:clap: good point!!!
S2 Number 640
paulsmithmk
Postby lotusnut » Fri 19.04.2013, 19:59
I should see you at the layby then Stef
lotusnut
Postby Stef » Fri 19.04.2013, 20:19
lotusnut wrote:I should see you at the layby then Stef
Fab!
See you there.
--- no dogs :wink:
Stef
Postby Eltel1st » Fri 19.04.2013, 23:10
Hi all,
I will be joining at junction 6A from the A10 junction 25 on the M25, might see some of you coming round the M25. Still new and can't find the edit button to add my name at J6A. I will be in the yellow one !
Terry
Eltel1st
Postby Steve A » Fri 19.04.2013, 23:35
Final list
J6A (M25) 0726
daveiow
Eltel1st
J8 (Hemel) 0729
Paul69
Gazza
J10 (Luton) 0736
Paulous
Newport Pagnell Serivces 0759
PaulsmithMK
J15A/Northampton Services 0810
DavidEJM
J19 (A14) 0828
Stef
Lotusnut
Postby rip » Sat 20.04.2013, 06:44
Eltel1st wrote:Hi all,
Terry
You can't edit another person's post (Moderators can).
Quote the post, remove the quote control tags & add your name.
Return to Events - U.K.
