BOLLECKS to Billy
Re: BOLLECKS to Billy
Postby madbilly » Wed 17.07.2013, 09:29
Okay, got it, was just waiting on confirmation for cricket and parts order at Williams' - unfortunately I can't arrange everything into one single happy trip, shame, I'll have to have more than one drive out in the nice weather!
So I'll see you at The Thames Head on the A433, GL7 6NZ. I should be there about 6 I think.
See you later,
Will
madbilly
Postby dapinky » Wed 17.07.2013, 11:01
Geoff, (and Pete - but at least you have been commenting recently!)
are you going :smt064 :smt064
If so, which way?
Google gives me a 'best' option of M5, M4, off at J18 (where i could meet you in the laybye just up the A46).....
...It also gives an option via M5 J14 then across to Tetbury ('B' roads) - which I suppose is better for you.....
....then there is an option to go M4 to J17 (A429) - which is (presumably) best for Pete???
All 3 options are within 6 miles and 2 minutes of each other for me, but if I hear nowt from anyone, I'll make my own way there without a 'convoy' :(
.....having looked at the menu, I can't be bothered to cook tonight and will eat there :D
Postby epipete » Wed 17.07.2013, 11:37
Dave, thanks.
For me the route is clearly via J17 up the A429. Satnav advises only 20 miles and 35 min door to door, there is a lay by just up (about 100yds) from the motorway turn off on the A429 if you want to meet. Just say what time! :burnout:
This route not so good for Geoff I suspect! His best route is via the A4058, A4135 & A433. You might wish to tag on to him - if he ever resurfaces! :chair:
Pete
Postby GeoffSmith » Wed 17.07.2013, 12:01
I'm going to be a bit late, so I'll see you there. I'm going to make a slight detour as I found an interesting road from the escarpment down into Wotton which looks like it will be even more fun going up, but it should still take me less than an hour.
Postby GeoffSmith » Wed 17.07.2013, 12:03
epipete wrote:... if he ever resurfaces! :chair:
Some of us WORK you know! :smt098
Postby epipete » Wed 17.07.2013, 12:20
Good, your buying then :clap:
Postby dapinky » Wed 17.07.2013, 13:53
epipete wrote:Good, your buying then :clap:
yep - us poor public-service pensioners have trouble making ends meet!
Pete,
What time are you looking at being anywhere - I'm fairly flexible and free!
Postby GeoffSmith » Wed 17.07.2013, 22:37
Despite the customary BOLLECKS lack of planning and coordination, it wasn't a bad night.
Good to meet you Will and good luck with the move - if you need any help with the Williams things, please give me a shout as it's virtually on the way home from my parents' new house.
Postby epipete » Wed 17.07.2013, 23:18
Bugger, overheated on the way home, car abandoned in a pub car park, collected by wife! After I'd called her I discovered the a hose has sprung off the heater matrix on the bulkhead, will return tomorrow to see if that is all that's wrong! :(
Postby dapinky » Thu 18.07.2013, 00:33
Just so you don't feel too bad about a slight overheating issue - it could have been worse......
......the rear wheel bearing noise that i mentioned on the vectra got steadily (and then substantially) worse until i reached Tetbury, whereupon i decided to stop and see what was happening, only to discover the RNS wheel hanging on by just 2 loose bolts :shock:
Luckily I had 4 spare bolts in the boot (from when it had locking ones fitted) so worked out how to use a Vauxhall jack in a dark layby - and then bent the ignition key trying to pry the jacking point covers off...
...got the wheel re-fixed and straightened the key with a kerbstone and half a brick - got home with no further issues, and even the "wheel bearing" is fixed now :oops: :oops: .....
....just can't get the slightly misshaped key out of the ignition lock - so that's tomorrows job when i can see whats happening and get some pliers on it.
Postby epipete » Thu 18.07.2013, 01:01
Sod's law that I was commenting on the (now mistaken) belief that all (3) of the families cars were running spot on for the first time this year, me and my big mouth :roll:
The engine bay smelt awful so I fear bad things when I return to it tomorrow, that said after my initial stop I was able to restart it for a 100 yard drive to the pub car park, the publican was very helpful and it is parked in line of site of his CCTV - not that anyone can nick it at present!
Sorry to hear of your woes, now you have a choice of cars to work on!
Postby madbilly » Thu 18.07.2013, 08:19
Ouch, sounds like it got exciting after we left last night! I'm pleased to say I just drive home, no drama, just enjoyable. Thanks for coming along, was good to catch up before we set sail.
Cheers,
Will
madbilly
Postby epipete » Thu 18.07.2013, 11:50
Ok, all sorted! Checked oil, reattached hose, refilled coolant; fired up 1st time, drove home, temp good, oil pressure good. Seems I got away with it!
Be glad when my new Samco hoses arrive!
Nice to see you Will, enjoy your new life in France it'll be great :burnout:
Postby dapinky » Thu 18.07.2013, 15:20
New battery in alarm fob got the red one back on the road - new wheelbolts for the Vectra keeps that one on the road - back to a nearly-all-working fleet :D
Will, hope it all goes as smoothly as it can, you and mrs madbilly soon find some suitable permanent accomodation, and your furniture arrives as efficiently as wished for.
Good luck for the next few years (and beyond!) - keep in touch.
Postby GeoffSmith » Thu 18.07.2013, 17:10
Well if you hadn't whined about my headlights, I might have been following you and been able to help. :lol:
Postby epipete » Thu 18.07.2013, 22:13
GeoffSmith wrote:Well if you hadn't whined about my headlights, I might have been following you and been able to help. :lol:
Nice one!
To make matters worse, tonight I met a pal in a local pub and ran out of fuel as I pulled in to the Carpatk, Doh!!!
I blame the unusual heat!!!
Postby GeoffSmith » Thu 18.07.2013, 22:37
:lol:
Postby GeoffSmith » Fri 19.07.2013, 20:47
Well that'll teach me to open my big gob. :(
Postby epipete » Sat 20.07.2013, 09:47
GeoffSmith wrote:Well that'll teach me to open my big gob. :(
Divine intervention I guess!
Postby dapinky » Sat 20.07.2013, 11:58
I've got one, I've got one, I've got one, I've got one, I've got one, I've got one, I've got one, I've got one, I've got one, I've got one, I've got one, I've got one, :bananasex:
Return to Events - U.K.
