Engine won't start
Engine won't start
Postby IanB1978 » Mon 29.05.2017, 21:12
The starter motor turns but there is no ignition and a strong smell of petrol, any ideas?
IanB1978
Re: Engine won't start
Postby muley » Mon 29.05.2017, 22:44
Crystal ball job. Are the plugs wet with petrol? Is there a spark at the plugs?
Has you car got an immobiliser? Is it off?
Etc
1995 Palacio S2 no 507
Postby IanB1978 » Sat 30.09.2017, 13:41
So update
I have checked sparks and 3 have weak sparks and 4th doesn't. It almost starts if I leave it a while but then just turns over.
Not sure what to check next??? Should I give up and leave it to the professionals?????
IanB1978
Postby HJ2 » Sat 30.09.2017, 14:16
Then I would suspect coil pack, but also check fuel injectors
Postby Rambo » Sat 30.09.2017, 19:21
It's only taken 4 months to get this far 8)
I would tend to agree with HJ as an initial starting point
Goldfish-brain
Postby IanB1978 » Sat 30.09.2017, 21:17
yeah unfortunately been working on a house which my wife says takes priority
IanB1978
Postby Simon_P » Sat 30.09.2017, 21:32
When was the last time you had it running and have you done anything to it since? Any recent service work?
Postby IanB1978 » Sat 30.09.2017, 22:53
It was running fine, had service and cambelt in March and went on some nice drives then the battery went dead. So I charged it and it hasn't started since, just turns over.
IanB1978
Postby Simon_P » Sun 01.10.2017, 02:57
How many volts do you get across the battery?
Unless it's new, that's where I'd start.
Have you tried a jump start?
Are the battery terminals clean and secure?
Before people put their cars in warm garages connected to battery conditioners, the trick was to get one from Halfords with a four year guarantee, then change it when it expired after two years and if needed and you had the nerve after 4.
Postby IanB1978 » Sat 11.11.2017, 16:22
Turns out it was the fuel cut off switch just pushed it down and boom started first time
IanB1978
Postby HJ2 » Sat 11.11.2017, 17:12
:lol:
Postby Simon_P » Mon 13.11.2017, 09:25
IanB1978 wrote:Turns out it was the fuel cut off switch just pushed it down and boom started first time
... And a strong smell of fuel
