No ignition lights on dash
Postby Lead pencil » Sat 12.12.2020, 16:23
Good afternoon
I have a bit of an issue been going on for about a year on start up it’s a lottery if I have dash lights or not. Car starts up straight away and no running concerns but Rev counter does not work if there is no dash lights by this I mean no cel light , battery light etc can drive of down the road it might work come on for a while then go back to zero. If I move dash clocks around with ignition on the lights will come on then
Next time I use the car back to no lights / Rev counter help needed doing my head in
Lead pencil
Re: No ignition lights on dash
Postby Rambo » Sat 12.12.2020, 17:15
I would start by checking and cleaning all the relevant earthing points
Postby Simon_P » Sat 12.12.2020, 19:57
there are 2 big connectors behind the gauges. one in a piece of sponge and one beneath it. check both of those particularly the earth as Rambo mentioned. Earthing point 2 is really hard to get to so it is easier to do resistance checks between wires going to it.
Postby Lead pencil » Sat 12.12.2020, 21:45
Thanks for your help I’ll have a look at your points and hopefully cure my issue I’ll let you know if it sorts out the problem
Lead pencil
Postby Rambo » Mon 14.12.2020, 17:05
Circuit diagrams available here http://wikilec.com/view/Electrical
