High CO MOT problem! Oxygen sensor defect or... ?
Postby HJ2 » Fri 11.09.2015, 11:12
Dear all,
During my last MOT the strangest thing happened:
With the O2 sensor in place, and the engine HOT, the CO % at idle was around 2,7%
With the sensor unplugged (so map based mixture only) the CO % dropped to 0.35!
(without any CAT)
Doe this mean that my sensor is faulty or that i have a leak in the exhaust somewhere around the O2 sensor, or does this imply another failure somewhere?
Is there a way to check if the current O2 sensor is functioning within specified band width? (for instance with elanscan)...
Any help appreciated!
Re: Oxygen sensor defect or... ?
Postby GeoffSmith » Fri 11.09.2015, 11:33
ES logs the O2 output voltages and indicates open/closed loop operation.
Postby HJ2 » Fri 11.09.2015, 11:36
Thanks geoff.
What voltage should I expect at idle?
I now read 0,3v ... 3,6v and it jumps all over with a cold engine.
Oxygen Integrator says 88 and later on 8A(?)
Knock counter is high allready :61!
Postby HJ2 » Fri 11.09.2015, 18:29
Small update:
I took the plunge and removed the down-pipe again.
It looks like the seal between turbo and down-pipe is questionable, but even worse: there is a leak in one of the welds from the down-pipe (NOT a piper weld, but one from my welder)
This leak is only 2 cm. away from the O2 sensor.
Could this cause my high CO?
(it's out now, ready for welding again)...
Postby HJ2 » Sat 12.09.2015, 12:56
Okay..
I see that I wrote CO2, where i meant CO! :oops:
Down-pipe leak is welded up, and I replaced the gasket to the turbo flange. Everything reassembled now, after I warmed up the Elan I tested again:
Hot engine @ Idle:
0,86% CO
13,54% CO2
Lambda 1.038
1,50% vol O2
Unplugging the O2 sensor did not change anything @ Idle anymore, so that's an improvement... But the value of 0.35% CO open loop disappeared as well!
However I unplugged the O2 sensor with a running engine this time, should I have restarted it first?
so, a lot better, but I still aim at 0.45% CO with the O2 sensor in closed loop.
Also Elanscan shows:
PROM Error (?)
Manifold Pressure 0.35 bar (is this okay-ish?)
Spark advance = 17
Oxygen Sensor varies between 0,4 ... 3,5
How / where in Elanscan can i see if the car runs closed loop or not?
Re: High CO MOT problem! Oxygen sensor defect or... ?
Postby GeoffSmith » Sat 12.09.2015, 13:16
Flag 42 bit 0
Postby HJ2 » Sat 12.09.2015, 13:17
OK!
