by *LUCA* » Thu 14.12.2006, 00:53
Hi from Italy....
I have changed the old CAS bearing with a new one but now I've a problem: I have lost the right position of the "HALL EFFECT SENSOR" with the "CAMSHAFT CONNECTOR". Are there somebody that can help me? Is good the "Right position" or the "Left position"? Can you show me some picture for my CAS?
<Thank'you>
- Attachments
- (59.71 KiB) Downloaded 181 times
- (59.4 KiB) Downloaded 171 times
*LUCA*
by paulwatkins » Thu 14.12.2006, 08:57
I've got my CAS off the car at the moment....so, if no-one replies with the info throughout today, I can take a pic of my CAS after work tonight....
Paul
paulwatkins
by ailwyn » Thu 14.12.2006, 09:46
Have a look here:
http://www.lotuselancentral.com/repair/cas.htm
The 3rd and 4th picture show the CAS, looks to me like the "right position" is the correct one, however your pictures are not from the same direction as the ones on that page, so don't take it as fact.
I suggest you hold the CAS at the same angle as the pictures and see if they look the same.
Ailwyn
- Forum Member
by *LUCA* » Thu 14.12.2006, 20:29
thank's to Paul and Ailwyn, but isn't simple to see the right position on that page....
So.....I need more picture guys...
Many many thank's and many greetings from Naples (Italy)
*LUCA*
by paulwatkins » Fri 15.12.2006, 08:28
Luca,
I will take some pics of my CAS for you.
I will have to do it tomorrow.
Paul
paulwatkins
by *LUCA* » Fri 15.12.2006, 17:41
Thank you again Paul.
*LUCA*
by Monty » Fri 15.12.2006, 18:41
Luca,
Have u got the manufactures part number for the bearing u replaced on the CAS? this would be handy for the rest of the members
- Chunder King!
by paulwatkins » Sat 16.12.2006, 14:09
Luca,
Here is a pic of my CAS for you to look at.
You can see that when the sensor part is in the same position as in your pictures, the camshaft connector protrusions are ABOVE the centre line (or as you have called it, the 'right' position)
Hope this helps!
Cheers, Paul
paulwatkins
by *LUCA* » Sat 16.12.2006, 16:05
Ok, thank you Paul, I have mounted the CAS unit like your's picture and now all is ok.
The the manufactures part number of the new bearing is 6000-2RSH for the SKF model. The price in Italy is 3,50 €.
There are then three O-rings:
1°) Located behind the CAS, on the shaft that connects to the camshaft.
2°) Located inside the CAS body, around the bearing.
3°) (Only for the oil leaks!) Located behind a plastic bung adjacent to the CAS.
There is, besides, an "oil seal" with this dimensions "10.22.7" (dimensions are in millimeters). In my CAS this "oil-seal" was very broken as visible in the picture!!
So...I can say: 6,50 Euros VS the CAS noise and the oil leaks!!!!
- Attachments
- (83 KiB) Downloaded 141 times
- (84.24 KiB) Downloaded 144 times
*LUCA*
