soft top fitting instructions
Postby Xavier T » Sat 26.01.2008, 14:11
Hi, because my soft top has been vandalised, i bought a new one. I'm looking for fitting instructions. Does anyone know where i can find them, or may be people which have them could scan? thank you very much
Xavier T
Postby dermotbell » Sat 26.01.2008, 19:15
LGM has fitted them successfully as I recall.
Giver her a PM or check the Wiki.
Dermot Bell
dermotbell
Postby Monty » Sat 26.01.2008, 19:21
KevH use to have a write up on replacing the roof but i no longer have it, not sure if it`s on the wiki as i can`t see it :?
Postby Xavier T » Sat 26.01.2008, 19:51
Thank you, i'm going to contact them.
Xavier T
Postby John_W » Sun 27.01.2008, 00:24
Xavier,
See this thread.
Also, download KevH's write-up as a Rich Text format file from here.
I tried to put it on WikiLEC but it didn't upload for some reason.
Postby GeoffSmith » Sun 27.01.2008, 01:33
John_W wrote:Also, download KevH's write-up as a Rich Text format file from here.
It's on WikiLEC now - if there are any mods/improvements, feel free to amend.
Geoff
Postby Xavier T » Sun 27.01.2008, 11:06
Hi, Thanks everybody for your hrlp. As i read the instructions, it seems i have to order all seals and elastic straps? Does anybody have references for these parts so i could send a message to my local dealer?
Xavier T
Postby Specky » Sun 27.01.2008, 12:43
Make the Elastic straps yourself ...
you will need new rivets....
and possibly new load spreading plates (Due to corrosion)
You can make / replace all these yourself..
Postby Ekapol » Mon 28.01.2008, 06:06
I recall LGM changed the elastic straps to black nylon straps of the same size. It makes better sense to me also no more worry about overcooked fettucini in the future.
Ekapol
