Water leak !!!
Water leak !!!
Postby discovery » Wed 04.05.2005, 08:20
After about 3 hours of being parked up in very heavy rain the space behind the seats was flooded !!!<br>Just a couple of drips from front screen ,not enough to worry about.  Any ideas please ?
discovery
Re: Water leak !!!
Postby Sy V » Wed 04.05.2005, 08:37
Ingress below (or down the sides of the glass into the bottom and out)  the doors across the sills is my prime candidate - were you on a slight slope per chance?<br>Followed by ingress above the B pillars.
LEC Godfather
Re: Water leak !!!
Postby discovery » Wed 04.05.2005, 08:41
yes,on a slight slope, front pointing up.
discovery
Re: Water leak !!!
Postby Sy V » Wed 04.05.2005, 08:46
My first option applies then.
LEC Godfather
Re: Water leak !!!
Postby discovery » Wed 04.05.2005, 08:54
Many thanks
discovery
Re: Water leak !!!
Postby John_W » Wed 04.05.2005, 13:01
Discovery,<br>this might help:<br>http://www.lotuselancentral.com/cgi-bin/yabb/YaBB.cgi?board=body;action=display;num=1092302865;start=10#10 <br>There's more tips around somewhere.<br><br>John
Re: Water leak !!!
Postby John_W » Wed 04.05.2005, 19:35
[quote author=John_W link=board=body;num=1115191211;start=0#5 date=05/04/05 at 05:01:30]Discovery,<br>this might help:<br>http://www.lotuselancentral.com/cgi-bin/yabb/YaBB.cgi?board=body;action=display;num=1092302865;start=10#10 <br>There's more tips around somewhere.<br> [/quote]<br>... like this one:<br>http://www.lotuselancentral.com/cgi-bin/yabb/YaBB.cgi?board=interior;action=display;num=1092381907;start=7#7<br> :)
Re: Water leak !!!Service Notes manual itself
Postby John_W » Wed 04.05.2005, 21:00
I finally remembered where all the "leak stopping" info is. It's not a Service Bulletin as I wrongly remembered - it's in the Service Notes manual itself. See Addendum no 1 "Water Ingress; areas of attention" pp 55-73.<br><br>It's quite comprehensive. Too comprehensive actually - I don't think you need to do it all.<br><br>About all they missed is adding extra foam seal (or silicon sealant) to the top of the windscreen to prevent water getting in past the header seal and dripping down at the A-pillar. This is a better solution than the "drain tube" method in my opinion, as it treats the cause (water getting past the seal, not the effect (water dripping onto your knees).<br><br>John  :)
FYI: Where to get rubber seals and glue in the UK
Postby jdey » Wed 20.07.2005, 22:32
You can order any 1 of the following:-
1. Rubber P Section P43
or
2. Plain expanded Neoprane PEN23
With either product, just glue it on top of the existing seal around the top of the windscreen. Both products are very flexible and can be cut to shape easily.
Thixofix contact adhesive A139 is fine as the adhesive
The basic idea is shown here:-
http://www.sealsdirect.co.uk/bbCMS/bbCM ... 9#section5
jdey
Re: Water leak !!!
Postby RayD » Fri 05.09.2008, 19:21
We had the car out in the rain for three days this week...
Looking for the source of a leak in the passenger side footwell I found this piece of sponge wet through. It’s directly under the large flat section of the dash and behind the glove box.
Does anyone know where the water may have come from? The A pilled seals are OK and the wheel arch liner is in place.
Ray
RayD
Re: Water leak !!!
Postby John_W » Sat 06.09.2008, 16:21
Ray,
I suggest it's the foam seal joint in the air inlet ducting which has perished, allowing rain and spray water into the air duct and then to the passenger footwell. It's been mentioned a couple of places:
here, and here for instance.
Re: Water leak !!!
Postby RayD » Sat 06.09.2008, 17:10
Thank you John,
Is it safe to assume it’s behind the passenger side wheel arch liner?
Ray
RayD
Re: Water leak !!!
Postby Sy V » Sun 07.09.2008, 06:29
Ah, this old cherry - yep, up in the innards of the wing. Not the easiest place to access but I agree with John's diagnosis.
Wrap the old sponge-like material with some tyre inner tube and you'll find your heater efficiency improves too although I'm not entirely sure why, but mine did.
LEC Godfather
