Is there more than one type of hood?
Postby basher » Sun 25.10.2020, 17:37
Back during lockdown I fitted a 2nd hand replacement hood to the Elan. All seems ok with it although I am aware that I have to do some adjustment to it as the back struts going back to the rear deck no longer lock into position and I have to reach in and lock them myself.
Previously to this, I have replaced the B post covers on the car to the newer version because the originals that I had in the Elan were cracked and broken and the caps and the springs to hold them down were long gone. The version I have now is the later one which has the single offset hinge each side and I had to hunt around to get the passenger side hinge. This was basically what I could get hold of and also I thought it was the better design as the ones fitted originally appear to have parted company from the car.
What I have noticed now is that the b post pillar is starting to get split by the hood mechanism coming out of it, pushing against it. Added to which the B-post caps don't really pivot up comfortably either.
So my questions are, firstly is there two types of hood and does the fitment of the different type of B-post cover matter or should they be interchangeable?
Or, is this just a case of adjustment.
ImageIMG_2285 by Michael Baldwin, on Flickr
basher
Re: Is there more than one type of hood?
Postby Rocklobster » Tue 27.10.2020, 16:43
Can't quite see the detail. Can you post a bigger picture please. :wink:
Pete
Rocklobster
Postby david924s » Tue 27.10.2020, 17:56
There were or are two hood types one originally for the SE and one for the later S2 Elan, not sure what if any frame changes were made but I know some of the seals are specific to one or the other hood type.
I have seen many SEs with the later S2 hood fitted as they are better material and have a wider guttering around the door windows etc. The B Pillar covers are specific to early or later cars.
david924s
Postby basher » Thu 29.10.2020, 19:48
ImageIMG_2290 by Michael Baldwin, on Flickr
As you can see, passenger side, the strut is starting to split the B-Post trim.
Is this a case of adjustment somewhere to move it away from the trim? Maybe its even become bent somewhere? I need to find what adjustment does what on the hood - any ideas where?
Or is there some issue with incompatibility where a certain hood has to go with a certain b post cover?
basher
