Just been on the phone to Peter at TRIM TECH,
He has informed that they now fit the header rail seal with"double Sided"
tape instead of the Betterseal Black Gunge used by Lotus which you have to leave for 2 days to cure.
He also does the other seals as well with the same tape.
So if you want to have a go your self
you could
give it a try. Dont fancy it my self though, but if you wanted to replace the header rail seal and other seals after cleaning out the "Black Gunge" it should be a lot easier. This seems a good tip from Peter as they
are not fitting hoods after he retires in July.
