Bonnet Sound Deadening
Re: Bonnet Sound Deadening
Postby NewLogik » Mon 06.07.2020, 12:05
Mike Y wrote:Ok so I received the sample and it looks a excellent match to the original so I ordered their min quantity and they manufactured and delivered within 5 days :-D :clap:
I will post more photos when I've cut it using the original as a template. At £56 including VAT and delivery its a fraction of the cost of shipping the ready cut product from the USA, and this is foil backed with self adhesive on the foil as per original spec. £20 of the cost was delivery which if you live near Melton Mowbray you could probably save yourself £22 of the £56 including vat :D Also the min quantity might do 2 bonnets? :D
Definitely looks good. Where did you order this one ?
Regards,
NewLogik
Postby Mike Y » Thu 09.07.2020, 12:17
The company is called
A.G.S Acoustic Materials Ltd in Leicestershire Call Richard he was extremely helpful. tel 01664 411770
The product code is N12/SA/FF/AG-LAM. :D
Mike Y
Postby nicowalker1 » Sat 27.03.2021, 17:48
Hi Mike, how did this work out for you? Was the quality as expected?
nicowalker1
Postby clemo » Sat 27.03.2021, 17:56
I remember the 1st group buy .. it was lotus logo with silver foil ....
any ideas if the original suppliers still have the template and can do another batch ? that is of course its on price , can be done , or mikey y's version is equally as good.
How did you get on Mike ?
clemo
Postby Mike Y » Tue 30.03.2021, 12:26
Hi
I have not fitted the finished article yet.
I must say the product is excellent and as per original fitment and very low cost especially if you live near Leicester. I will be experimenting how best to cut to shape soon I have the old sound deadening as a template. I will post photos when I get back on to working on JUFs in the next month.
Cheers Mike
Mike Y
Postby TrevorB » Sun 11.04.2021, 14:18
Mike Y wrote:Hi
Cheers Mike
Mike, have you managed to fit this yet?
My original bonnet sound deadening was slowly disintegrating so I have removed it and put in a temporary replacement. Would obviously like to replace it with a better looking
item that is more consistent with original.
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby ElanSteve » Tue 08.06.2021, 17:35
Update for those in the US.
Classic 9 Leather shop says they are no longer available for unspecified technical reasons ( I phoned them this week).
Little British Car Company is trying to order one for me. I think their supplier was Classic 9 though so I'm waiting to hear if they can fulfill my order. The guy at LBCC reckons the Classic 9 mat didn't have the foil either. So I'm debating whether or not to figure out how to put some foil down before the insulation - maybe some of the relatively thin foil-foam-foil sandwiches.....
Meanwhile continuing the messy job of trying to remove all the old sealant holding the panels together.
Steve Brightman
Monument CO
ElanSteve
Faecesbook convict
Postby Mike Y » Mon 12.07.2021, 11:35
Hi Everyone
I finally got around to cutting the sound deadening I can confirm the product is identical to original spec in all respects including foam density. :D It is very easy to cut using good quality sharp scissors. I found the best way to mark out the outline was to draw around the original foam black / Foam side up as the new adhesive backing paper is waxy so ink just rubs off. I will attach photos.
Mike Y
Postby Mike Y » Mon 12.07.2021, 11:47
Here is a photo of the old and new foam against each other the old foam is a lighter grey colour due to age. This shows the foam density etc is identical to original spec. I fitted new Lotus supplied original foam to JUFs back in 1999 and I can certainly confirm this product is 100% to the original spec.
Mike Y
Postby ElanSteve » Tue 03.08.2021, 19:29
Bonnet refurbishment post script. Some thoughts for those contemplating this and lessons learned. If I was ever to do this again....
    1. It's a messy job, that black goo gets everywhere. Cleaning it all out was the longest and messiest part of the job.
    2. I spent a lot of time messing with aluminum foil to try and duplicate the original. Next time I wouldn't add the foil at all. I measured the dc resistance from one side to the other after all the foil was in place, it was basically infinite so not good conductivity though the glue holding the sheets in place. Not necessarily bad for suppression purposes where capacitive coupling would be more important. I meant to run some tests before reading the bonnet, but forgot. Once in place I tested with the bonnet open. No discernible radio interference across the AM or FM bands.
    3. Don't waste your money ordering custom fit insulation. Much cheaper to just buy a roll of closed cell foam of your choice. The inner shell is a perfect template to trace the outline on your insulation and give you a perfect fit. Don't bother with the "ears" that go up to the hinges.
This was part two of my delamination refurbs. First was the cover over the convertible top which covered my fingers in black goo every time I raised/lowered the roof. We fixed that in place by scraping out as much goo as possible and resealing with epoxy. The boot lid now wants to join the party! Again I will scrape out the goo from the corners and attempt a repair without completely separating the two halves.
Steve Brightman
Monument CO
ElanSteve
Faecesbook convict
Postby GeoffSmith » Tue 03.08.2021, 22:44
Not bad for a scientist.
Postby Mike Y » Thu 05.08.2021, 23:11
The foam I have sourced requires [i]NO GLUE[/i] it is self adhesive as per the original.
Closed cell foam is readily available in the UK as is closed cell foam with a foil face but the problem is the modern products have the self adhesive glue on the foam leaving the foil facing the engine bay. The company I contacted now specially produce the foam backed with foil and place the self adhesive glue on the foil as per original spec for Elan owners as per the product code given else where on this thread, leaving the black foam facing the engine as per original. It is an exact match. The price is no different to the off the shelf product with the glue on the foam so it is reasonably priced comes straight off a roll for you to easily cut yourself as per my photos. The minimum order quantity will cover 2 bonnets including the smaller front bonnet pad, making it in UK pricing approx £30 per bonnet. :D
Mike Y
Postby Mike Y » Mon 13.09.2021, 14:18
Finally fitted!!! :D
With foam removed from the wings under the hinges exposing the foil backing as per original spec.
I am pleased with the result. :D :D
Mike Y
Postby Tuga2112 » Thu 23.09.2021, 08:21
Mike Y wrote:The foam I have sourced requires [i]NO GLUE[/i] it is self adhesive as per the original.
Mike,
can you forward the details about this company so i can put down the order for enough foam to sort out both my cars please
Postby Mike Y » Mon 27.09.2021, 10:35
Mike Y wrote:The company is called
:D Excellent product exactly as original
Mike Y
Postby clemo » Mon 27.09.2021, 21:11
Thank you Mike.
clemo
Postby Tuga2112 » Thu 09.12.2021, 15:27
Called AGS and spoke with a Fellow called Alan
I've asked him about the product with code "N12/SA/FF/AG-LAM" as previously mentioned which apparently doesn't match the description of the foam originally used in the bonnet
after some discussion he explained bonnet deadening materials have the foil on the side of the engine to protect the material from the engine heat (somewhat explaining why ours need replacing?)
I've showed him this thread and he came back with this.
Hello, Joao ?, Found out the Material you’re after.
Ref AG-Foam N12/SA/FF Sht size 1000mm x 1200mm x13mm thick.
Product description Black 12mm Acoustic Foam (non Flammable)
Self-adhesive backing
Foil facing (heat protection)
Ideal for car bonnets.
Price Each £28.40 + VAT
Delivery 2no sheets £35.00 +VAT
Delivery Leadtime 3/5 days
We would advise using a contact adhesive as well, sprayed directly on to the bonnet and then install the AG-FOAM.
Contact adhesive 500ml can £7.80 each +VAT
Hope this explanes everything.
Ordered the recomended foam which arrived today, I will have a look over the weekend to confirm its exactly as the original or not and post back results.
Postby Mike Y » Thu 09.12.2021, 16:27
Richard stated he would get the glue placed on foil side which is the opposite side to their normal foam. He stated he would do this specially for Elan customers which I can confirm he did for me. The minimum quantity I ordered will do 2 bonnets it is EXACTLY as per original I can confirm I have posted photos of the original and AGS product together.
See also my thread Black SE Re-shell and Chassis Cont'd in the project Major section
:D
Mike Y
Postby Tuga2112 » Mon 25.07.2022, 19:44
well. mine does not have the glue on the foil side. so im kinda stuck with the "standard" non original instalation unless i can figure out a way to remove the glue from the black side
Postby Mike Y » Tue 26.07.2022, 16:03
Ive already been through all this and it does EXACTLY match the original!!!! I've already cut and fitted this to my car SEE:- SE Black Re-shell and Chassis Cont'd I discussed this at length acouple of years ago with a specialist at this company hence why I posted it here.
See my posts on the subject :roll: :bonk:
Mike Y
Users browsing this forum: Google [Bot] and 11 guests
