Bodyshell ?
Postby Paul.P » Sun 31.12.2006, 17:23
Gary wrote:Ok it seems that I may have overstated the 800 improvements. It is 'over 100'.
Bet you can't name anywhere near 100 ?
Also bet ( apart from a few like galvanised wishbones ), they ain't actual improvements. Just can't see that it was viable to invest more money improving the car, when they knew they were only gonna make 800, & the whole purpose was to raise funds for Bugatti. I'm fairly sure most of the DIFFERENT parts are there because they ran out of SE ones.
Postby Paul.P » Tue 02.01.2007, 23:12
Bringing this back to the original question of what is a Rest of the World RHD body, what countries would this be applicable to ?, only ones i can think of is Australia & Japan, any others ?
Only possible difference we can think about is the rear spoiler, apparantly the fed one is different, could this possibly be on this body ?, anybody got a pic ?
Postby surfboardfiller » Wed 03.01.2007, 00:33
Paul.P wrote:Bringing this back to the original question of what is a Rest of the World RHD body, what countries would this be applicable to ?, only ones i can think of is Australia & Japan, any others ?
I think generally the West Pacific is full of RHD countries From Japan to South Africa (like Taiwan NZ & indo).
Body differences I have heard of:
Fed front bumper
Back reg plate cover
Rear clam shell corners (where the shell meets the rear lights)
Reflectors on the side of the fed Elan
If you have a look at the parts guide there are numbers for each part, where the parts differ in other countries there is a different part number.
eg Door shell page 10.15 a there seems to be a change in the UK spec and the usa different again.
So if you were looking for a specific part then you may find it and see how many different part numbers there are. eg Rear topshell has three part numbers including stage one and stage two.
Hoping that this may be of help, but suspecting I may just be embarrasingly stating the obvious.
What are you up to anyway? I thought you were just building another elan from the chassis up, but now I'm not so sure....
Cheers anyway & Happy new year to all!
surfboardfiller
Postby Paul.P » Wed 03.01.2007, 07:18
Phil, if ive got the chance of a new tub in the lotus aftersale for £75, then i would change the one on my car, although its been repaired, it would be nice to have a new one, to go along with all the rest new parts !, but obviously no point getting it if its not a straight swap ?
Postby Dico » Wed 03.01.2007, 16:45
I have been reliably informed that the rear wing on this shell is the 'federal' type.
Guess your'e not as lucky as me then eh me old flat footed pal :wink:
edit- this guy has two UK spec rear wings (in black :P ) if you are prepared to go to the trouble of swapping em???
http://lotuselancentral.com/forum/profi ... ile&u=1936
Postby surfboardfiller » Mon 08.01.2007, 12:38
Paul.P wrote:Phil, if ive got the chance of a new tub in the lotus aftersale for £75, then i would change the one on my car, although its been repaired, it would be nice to have a new one, to go along with all the rest new parts !, but obviously no point getting it if its not a straight swap ?
I guess that an new tub is rear bodyshell?
For £75 you might as well buy it and see hadn't you? if it doesn't fit I am sure you could sell it on and get your money back? and if it does fit you could sell the old one and get your money back :-D
surfboardfiller
Postby Paul.P » Mon 08.01.2007, 19:14
surfer - Phil wrote:I guess that an new tub is rear bodyshell?
Phil, talked to Lotus Technical last week, who told me tub was not the same as Uk SE, main difference was that it utilised federal rear wing, so this put me off as there nolonger available, also like i said, it needed to be straight swap !
Postby surfboardfiller » Mon 08.01.2007, 21:26
Well now you have the answer it will save you the hasstle of finding out the hard way.!
What's wrong with the one you have is it still not right or are you being a perfectionist?
surfboardfiller
Postby Paul.P » Mon 08.01.2007, 21:34
Just being a perfectionist really !
Postby surfboardfiller » Mon 08.01.2007, 21:44
Paul.P wrote:Just being a perfectionist really !
Good Man! I guess that's why you own an Elan :-D
surfboardfiller
Postby Enright » Mon 08.01.2007, 22:09
Wow that's quite an opportunity though.
I mean, surely if you wanted to get rid of the "dreaded" vertical line/gap, then if you have the tub it's easier to neatly cut down the rear spoiler to fit the body.
The only issue is making some risers to ensure that it lifts the spoiler off the boot by the correct amount.
Postby Paul.P » Mon 08.01.2007, 22:16
Enright13 wrote:Wow that's quite an opportunity though.
Phew Neil, this is just what i didn't want to get involved in ( complicating it ! ) for lots of reasons mate !
Postby GeoffSmith » Mon 08.01.2007, 22:19
Not least the fact that I'm picking up one bodyshell already. Give me a break you two!
Postby Paul.P » Mon 08.01.2007, 22:26
geoffsmith wrote:Not least the fact that I'm picking up one bodyshell already. Give me a break you two!
Hey Geoff, if it was straight swap, i'de be there mate, but it ain't, requires time, work, space & more money, of which i'm short of all at the minute. I was gonna store it if i got it. Little things peeps don't realise are, the rear wing cost £200 to have decaled & lacquered, & it would have to be changed !!!!!!!!!!
Postby surfboardfiller » Mon 08.01.2007, 22:55
What are you going to do with it Geoff? wear it as fancy dress, build a boat (or a cool submarine) or is it going to be made into bespoke arty furnature for the dockside 'apartment'? :-D
Or just sit in your garage with the willwoods? :smt043 :poke:
surfboardfiller
Postby GeoffSmith » Mon 08.01.2007, 22:58
Phil,
I'm going to bury you in it! :smt097
Geoff
Postby surfboardfiller » Mon 08.01.2007, 23:06
geoffsmith wrote:Phil,
Geoff
How are you going to do that? you'd have to catch me first and you drive an S2! :twisted:
surfboardfiller
Postby ailwyn » Tue 09.01.2007, 01:50
surfer - Phil wrote:you'd have to catch me first and you drive an S2! :twisted:
Says the guy who trailed me all the way to the bridge :D
...I know, I know, you were just being courteous :D
Postby surfboardfiller » Tue 09.01.2007, 08:54
I thought you were driving slowly because it was night :shock: Please don't tell me you were flat out, Iknow it was because you have 148 litres of water in the passanger footwell :lol: I can see why you S2 guys need to fiddle with your cars and chips :-D
surfboardfiller
Postby GeoffSmith » Tue 09.01.2007, 13:44
With Ailwyn and Pontypridd baths on board, it's got a 0-60 time of 3.2s (downhill) :lol:
