Header Seal..The new concept..
Re: Header Seal..The new concept..
Postby chrisP » Tue 13.09.2016, 12:24
Can you give us an idea of which donor car, is good for the seal that runs across the roof between the a-post seals?
Cheers in advance
chrisP
Postby simonbuk » Wed 14.09.2016, 15:01
Jamie was given some seals by a scrap yard man but unfortunately didn't know what they were off so unable to help further.
Think we've got to start trawling scrap yards !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby chrisP » Sat 17.09.2016, 23:12
Oh that is a shame, I will be crawling around a few yards soon - a winter project!!
chrisP
Postby epipete » Sun 16.10.2016, 23:02
simonbuk wrote:So what were the seals used and how were they joined together so they look like one piece ?
This is the million $ question, I can familiarise myself with any number of scrap yards but how do you 'shape' the joins, and what with?
Truly, this is impressive work.
Postby Jamie N » Tue 18.10.2016, 21:51
The actual seal that I have on my Elan is custom made from different sections guys so its not a seal you can go and take off another car, however the good news is there are other alternatives that are capable of performing just as well, one of the better ones of the different seals i have made the front header from was the one on a Ford Cougar, the seal that the door shuts against, its a pillarless door and the seal is on the frame of the car, not on the door. The other small profile seal which attaches to the hood where the nasty old seal was, can be found on any older small Mazda (323/5 etc) or a Toyota Aygo, its a long strip located under the bonnet rear edge pinned to the plastic trim that surrounds the wiper mechanism. These EPDM seals will only really work if you already have EPDM A pillar seals as they wont bond to the originals very well, not that you would want to bond anything to rotted sponge :D . There are several ways of bonding EPDM and making a good permanent bond, Google is your friend!.
If you are good with your hands its a project well worth taking on, putting the header seal on the top windscreen ledge truly is the way to go (Its how most modern convertibles are sealed), but be aware, if you manage to pull it off and construct something so very neat, tidy and waterproof you may well be chastised, scorned,talked and lied about behind your back by certain individuals for daring to be so avante garde!, but we have a saying in Scotland which is the perfect response to the dissers.... "Get it right up you". :-D :-D :-D :-D :-D :lol: :lol:
Monaco S2 #406
Jamie N
Seal God
Postby muley » Tue 18.10.2016, 22:25
:agree: :goodposting: :m100:
:bowdown:
Postby Steve A » Mon 24.10.2016, 13:00
I went to a breakers yard today and bagged some Cougar seals :D
Postby lotusflasherman » Mon 24.10.2016, 13:59
Steve A wrote:I went to a breakers yard today and bagged some Cougar seals :D
better not tell my wife "I'm looking for a Cougar"... :bananasex:
Postby HJ2 » Mon 24.10.2016, 15:54
:lol: :bananasex: :clap:
Postby Steve A » Mon 24.10.2016, 15:59
:smt043 :smt044
Postby HJ2 » Mon 24.10.2016, 18:53
Hmmmzzzz... Cougar Seals....
Postby Steve A » Mon 24.10.2016, 19:07
HJ2 wrote:Hmmmzzzz... Cougar Seals....
Watch this space :wink:
I would have thought the Ford Cougar was a rarer sight in the Netherlands
Postby Jamie N » Tue 25.10.2016, 09:07
Nice one Steve, good to see someone taking on the task of replacing the worst seal on an Elan !, mind any advice needed just ask :wink: .
Monaco S2 #406
Jamie N
Seal God
Postby Steve A » Thu 27.10.2016, 16:12
Today I had a look at the possibilities of using the Cougar seal.
This is how it sits in the gully without any alterations, I then cut away the "leading leg" with a stanley knife for a better fit (photo to follow)
This is a before and after with the leg removed (LHS)
This is with the roof closed and the seal held roughly in position , ideally it would be more flush with the edge when secured
but this is just a dry run :wink:
There are plenty of things to figure out yet but it's a promising start :D
Postby simonbuk » Thu 27.10.2016, 16:50
Keep us posted ! I have just joined the Ford Cougar owners club in the hope that they might be able to help !
Can't quite see what bit you cut away ? How are yoh going to deal with the corners/ends ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Steve A » Thu 27.10.2016, 18:15
simonbuk wrote:Keep us posted ! I have just joined the Ford Cougar owners club in the hope that they might be able to help !
You will be able to see where I cut when I post the other cross section photo (I can't get to it until I get back home :wink:)
As far as ends and corners go I'm still in the process of figuring that little problem out, the relationship between the front upper window seal
the A pillar and the Header seal will not only have to be pleasing to the eye but most important of all WATER TIGHT.
Earth calling the seal wrangler :poke:
Postby Steve A » Fri 28.10.2016, 00:31
This has "the leg" removed
Easier to spot the difference
Postby chrisP » Fri 28.10.2016, 12:52
Great work, the photos help alot.
I purchased some Loctite 480 glue for joining the seals, you seem to have to abrade the seal and clean with alcohol - I am still working on getting a good bond
chrisP
Postby Steve A » Fri 28.10.2016, 14:17
chrisP wrote:Great work, the photos help alot.
Hi Chris,
I'm a big fan of Q Bond as seen on you tube (yes it really is that good) you can get it on eBay, not that there's anything wrong with 480, I'm just sticking with what I've used before.
I used Q Bond to join the two Cougar seals end to end as one seal isn't quite long enough, a bit fiddly but done and ready for the next stage. :D
Postby Steve A » Sat 29.10.2016, 18:29
:D I've had a busy day
All the glueing was straight forward, I think I achieved a good clean join.
I am pleased with the result, the join's are easily strong enough.
It's not finished yet but I've come along way.
