Header Seal..The new concept..
Re: Header Seal..The new concept..
Postby basher » Mon 07.11.2016, 23:24
Cheers for the offer Steve, I might have to pop round and have a look.
I have got a set of Jamie's 'a' pillar seals and my header seal is starting to look a bit tired in places.
Par,
As luck would have it I was looking at a seal to go around the bottom of the door, ordered some to look at and they sent me some of that d-profile in error instead, so I actually have some of this in stock, which is handy.
basher
Postby Steve A » Mon 07.11.2016, 23:55
par wrote:
basher wrote:
which ones are you fitting to the leading edge of the hood?
thanks
Mike
I was lucky enough to get one of Jamies combined header & A pillar seals, think it was a development/prototype set but it fitted perfectly.
I used this seal for the leading edge of the hood:-
https://www.amazon.co.uk/gp/product/B01FSE3G3U/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
It provides a good rubber on rubber seal which I have tested and doesnt let any water in but I do intend to adjust the roof catches to increase the clamping force and lower the front edge of the hood as advised by the Seal Master himself. I believe the under bonnet seal from a Toyota Aygo is also a good fit.
What are you using for the two front seals that were apart of the old header seal :poke:
Postby par » Tue 08.11.2016, 00:46
Scott J who owned the car prior to me had previously comissioned Jamie to replace the A-pillar & intermediate seals with EPDM versions and at the same time the front sides were replaced with EPDM versions also crafted by Jamie. In terms of my cars hood it is only the falling pillar seals that remain of the soakupalot sponge material.
par
Postby Jamie N » Tue 08.11.2016, 10:51
The easiest option for this part of the conversion is to remove the side sections from the original header (provided they are not too delapidated of course) and shape the ends to fit the new arrangement, that will allow you to do the job fairly easily and get it pretty much completed. The ultimate way to do it, is make brand new EPDM side section seals which can be constructed from donors, applying yourself with single minded determination can yeild something which can look and work as good and proffesional as something factory made, but commitment is a prerequisite!. Find the motivation and you will have an end result which will give you a great sense of self achievement, look and work superior to the original, and most importantly preclude the need to shell out a big wad of cash ;-) .
Monaco S2 #406
Jamie N
Seal God
Postby kimsel » Sun 28.05.2017, 03:59
hello I've been looking for the part that's on your 4th photo. Do you have any willing to sell those? if can how much would it be??
Or if you know where to find it please let me know Thanks...
kimsel
Postby thirou » Sun 14.01.2018, 12:14
That's really an impressive job.
Thank you Jamie for sharing it.
When I look at my seals, I tell me I really need to change them.
thirou
Postby Jamie N » Sun 14.01.2018, 21:45
Thanks Thirou, Those ones were the very early versions, recent ones are even better and they come with the hoods forward seals which correspond with it.
Monaco S2 #406
Jamie N
Seal God
Postby Jamie N » Fri 03.08.2018, 19:18
Just a quick update on the latest version of the hood seals which go with the one piece header and A pillars combined seal, these ones have an even
nicer finish. Probably the best ones yet, probably a hell of a lot of work :-) . (logo only indicating what they are for :D )
Monaco S2 #406
Jamie N
Seal God
Postby clemo » Sat 04.08.2018, 13:24
Looking good .
Are these the ones that mate up to the front seal that i already have ...
If so can you guess the next question ? !
clemo
Postby Saltire » Sat 04.08.2018, 16:53
I have them, Clemo. And they do mate up with the front one. And they’re brilliant - although they do take quite a bit of fettling to achieve a good fit all round. Thoroughly recommended.
Postby Kiwi » Sat 04.08.2018, 19:52
Jamie,
The seals look great on the car, looking forwards to no more leaks or wet knee and thanks for fitting them for me.
Top job.
kiwi
Kiwi
Postby clemo » Sat 04.08.2018, 20:25
Saltire wrote:I have them, Clemo. And they do mate up with the front one. And they’re brilliant - although they do take quite a bit of fettling to achieve a good fit all round. Thoroughly recommended.
excellent ... mine are a right mess especially the front corner return bits ....
clemo
Postby Steve A » Sat 04.08.2018, 23:38
Hrmmm they look familiar 8)
Postby lotusnut » Fri 18.01.2019, 10:31
How can I get set please
lotusnut
Postby Bern » Fri 18.01.2019, 11:43
I'll need a set too, at some point in the future, along with a new roof.
At the moment I'm going to get one of those hand held water vacuum cleaner things!
'90 Elan SE
'95 MGF
'16 Renault Zoe
'03 VW Transporter
'72 Land Rover 88
'80ish Kubota B5100E
Bern
Postby Jamie N » Fri 18.01.2019, 19:03
lotusnut wrote:How can I get set please
I only have the one piece header and A pillar combined seal and the 2 forward seals on the side of the hood, this is the seal in the picture
below, it does away with the original design which had separate A pillar and header seals made from easily disintegrated sponge, the new type is
EPDM Rubber.
The new design incorporates both A pillar seals and the Header seal as a single unit, most modern convertibles have their seals set similar to
that, MX5, S2000 to name a couple. The ultimate solution replaces your header seal and A pillar seals in one go.
You can see how waterproof it is by clicking on this video called 'rubbery stuff' :wink:
Monaco S2 #406
Jamie N
Seal God
Postby lotusnut » Fri 18.01.2019, 20:07
Cn you PM me with a price please Jamie
lotusnut
Postby Chas54 » Tue 21.05.2019, 19:46
Hello Jamie?
I have just bought an m100 elan and saw that you may have a modified set of A pillar seals and header seal as one piece. The photo looks good.
Do you have a set for sale at all, mine are a bit ropey.
I don't know if I am using the correct procedure for contact on this forum. so apologies if not
Charles Lyford
Chas54
Postby djwazza68 » Sun 03.11.2019, 09:41
Hi Jamie
I have the standard problem with the seals on my new project. Do you still make the kits and if not do you have instructions you can share? Can you please pm me as I'm still a noob so can't pm yet.
djwazza68
Postby robertverhey » Sun 03.11.2019, 10:06
I am in the market for your combined header-a pillar seal as well. Still available?
robertverhey
