by tomatcbl » Mon 25.04.2016, 02:03
The rear window in the hood of my federal elan is completely clouded and none of the many products I have tried will clean it.
Has anyone replaced their hood on a federal elan. If so what supplier did you use?
Many thanks
__________________________________________________________________________________
Tom
1991 Yellow M100
Maryland
tomatcbl
- Tinkerer
by Brit-Car-Nut » Sun 15.05.2016, 17:41
Tom: You should visit a decent trim shop and see what they will charge to replace the rear window. They probably can't "high frequency weld" it in place, but good trim shops have been replacing convertible top windows for years. They use a good, waterproof thread and a sealer to prevent leaking. As long as the fabric is in good condition, that would be my first research. While apart, they could fix any strapping or wear issues that might have cropped up over time.
by tomatcbl » Tue 24.05.2016, 14:31
Thanks for all the posts - I will start at a trim shop and see where I get - certainly it can't be any worse than it is.
Tom
1991 Yellow M100
Maryland
tomatcbl
- Tinkerer
by lotusflasherman » Tue 24.05.2016, 14:50
tomatcbl wrote:Thanks for all the posts - I will start at a trim shop and see where I get - certainly it can't be any worse than it is.
I've often thought about getting a trim shop to change mine to a zip in rear window. Has advantages in use and dead easy to get replaced in the future. Is now the time for you?
