by Kathryn » Wed 08.08.2018, 20:05
Has anyone fitted a front splitter?
All I can find is this
viewtopic.php?f=30&t=14636&p=193901&hilit=Chin+spoiler#p193901I can’t tell from the photo if it looks any good or not!
I thought Jamie had fitted one, but looks like that was just a different lip.
Palacio S2 #540
Kathryn
by clemo » Wed 08.08.2018, 20:37
The original came from Walker rubber . it has been known for the Renault Laguna more rigid plastic version to be fitted.
Though i am sure Jamie will have found some alternative version .... probably Honda based !
Might be these guys ... based out on lotus country
https://www.walker-rubber.co.uk/shopmay be worth sending them an email ...
clemo
- LEC Administrator
- Location: TORQUAY Devon. Cream first then Jam obviously.
by Elanlover » Wed 08.08.2018, 20:39
I have fitted this splitter of the Esprit and it does look very nice. Much better than the original rubber skirt. Takes a bit of work with a heat gun and then trmming the ends a bit but it's a nice little upgrade.
by clemo » Wed 08.08.2018, 20:42
Elanlover wrote:I have fitted this splitter of the Esprit and it does look very nice. Much better than the original rubber skirt. Takes a bit of work with a heat gun and then trmming the ends a bit but it's a nice little upgrade.
do you have a photo ? sounds very interesting would be nice to see it .
clemo
- LEC Administrator
by Giniw » Wed 08.08.2018, 21:07
The splitter of the S4 Esprit was no longer available until recently.
It is now remade by a few sellers, but it is rather expensive, especially for something that will rub the floor on too many occasions ... £120+VAT+shipping for a single side.
I wouldn't bother and would stick to the walker rubber rubber lip. Consider being lucky that it's available and cheap (the Esprit rubber lip (late V8) is more like £100, which is expensive but still much cheaper than the splitter)
left:
http://www.thelotuscentreonline.co.uk/e ... A082B5083Rright:
http://www.thelotuscentreonline.co.uk/e ... A082B5084RI think I remember SJSportscar has them too — I suspect they all come from the same factory as they all surfaced at the same time.
Giniw
by Kathryn » Wed 08.08.2018, 22:35
I know I can get the rubber lip, I was thinking about something that protruded a bit more. Offer a bit of protection should one accidentally drive into something at bumper height.
Palacio S2 #540
Kathryn
by Elanlover » Wed 08.08.2018, 22:52
There are TONS of universal fit front spoilers on ebay (
like this one) that can do the job at a low cost and look better than the original rubber strip. Just search ebay or google for it - lots of choices out there.
by muley » Thu 09.08.2018, 08:30
A very timely discussion. I noticed how p_poor the one on Ribena is (while I was replacing the radiator - another story)
So, do I go for carbon fibre effect? There's a shedload of choices out there)
by muley » Sat 11.08.2018, 19:04
FWIW I have fitted them in the past without the Meccano pieces. Just use penny washers and coax the lip round the corner
by Giniw » Mon 13.08.2018, 13:58
ready to print patterns on typical A4 sheets (21*29.7mm) (made after someone else drawing on a much larger sheet)
front:
https://www.mirari.fr/dUlg (print one)
sides:
https://www.mirari.fr/S01X (print two)
(print at original size, from image dpi — i.e. 300 dpi — to get the drawing at the correct scale. I included two references bars to check the print size on the paper, they should be exactly either 6 inches or 200mm)
Giniw
by muley » Wed 15.08.2018, 07:46
by Kathryn » Wed 15.08.2018, 19:25
Is that the one you fitted Jim?
I can’t say I watched the whole video but that’s not really what I want!
I’m looking for something that will protect the bumper should I, perhaps, maybe, accidentally drive into a concrete step in a parking space, for example.
Palacio S2 #540
Kathryn
by Brit-Car-Nut » Wed 15.08.2018, 22:01
I don't think the front spoiler lip was ever meant to do anything but look good. It might alter the air flow under the car, but it is just soft rubber that is set at the rearward end of the bumper so won't protect the bumper if you go over a high step or similar block.
A lot of people use "roll-up" garage door lip seals that can be found at the normal building supply stores like B&Q and are available in white or black. Several sellers on eBay are selling those at huge mark-up prices.
There are numerous listings on eBay for front bumper splitters like this (I am NOT recommending this seller)
https://www.ebay.com/itm/98-x2-5-Univer ... 2691355361?
by Kathryn » Wed 15.08.2018, 23:12
Brit-Car-Nut wrote:I don't think the front spoiler lip was ever meant to do anything but look good. It might alter the air flow under the car, but it is just soft rubber that is set at the rearward end of the bumper so won't protect the bumper if you go over a high step or similar block.
Yeah I know that!
And my lip is currently caked in mud after I parked in a muddy field so doesn’t look good either!
Palacio S2 #540
Kathryn
by Brit-Car-Nut » Wed 15.08.2018, 23:17
Kathryn wrote:Brit-Car-Nut wrote:I don't think the front spoiler lip was ever meant to do anything but look good. It might alter the air flow under the car, but it is just soft rubber that is set at the rearward end of the bumper so won't protect the bumper if you go over a high step or similar block.
Yeah I know that!
Maybe a set of "affordable" proximity sensors mounted in the front grilles would give you an audible warning?
by Saltire » Thu 16.08.2018, 07:38
Perhaps something like
this?
- Location: Left foot in Wiltshire, right foot in Gloucestershire, heart in Scotland
by Fredjohn » Thu 16.08.2018, 07:55
Great find Jonathan, but you can get reversing sensor kits off ebay for under a tenner! Fitted some to my campervan : very effective!
by Saltire » Thu 16.08.2018, 13:47
Agreed, John, but all the ones I’ve seen involve drilling the curved surface of the bumper accurately. Not so easy to do, and takes away the original look. (For the record, though, I haven’t fitted either option to my S2).
