Deformation of the rear light white transparent lens
Postby M100TURBOFR » Tue 14.05.2019, 14:41
Hello
Have any of you encountered a similar problem? What could cause this deformation - heat (internal/external), heat from the bulb?
Not my car but might be of interest as a topic (MOT failure!!)
Regarding this, the rear light protective cover manufacturer (Group Buy section) who I have found can offer all the lenses for the rear lights (red/amber/white) - in fact, are there not 4?? - if you were to encounter the same deformation problem.
I'd like to hear what the possible cause could be.
M100TURBOFR
Re: Deformation of the rear light white transparent lens
Postby Simon_P » Tue 14.05.2019, 15:57
Heat from the bulb.
Either it has been left in reverse or the light has stayed on for some reason.
Same 20w as the brake and indicator which are all intermittent. The Fog has a metal heatsink.
Postby Fredjohn » Tue 14.05.2019, 16:25
I have a similar problem on the driver's (UK) side, again with the reversing light. I know that the reverse switch sticks on, so this would seem to confirm Simon's diagnosis.
I disconnected mine except for the MOT! But if a new lens is available, I'd be interested, provided I don't break the undamaged cover trying to get at it.
Could also do with a new reverse switch. Anyone? (Yes I know SJ's and Rockauto have them).
Postby John_W » Tue 14.05.2019, 16:57
I wonder why that would be an MOT failure. It’s not as if reversing lights are actually any use at illuminating where you’re going on a dark night. They’re really just reversing indicators, so as long as it illuminates a white light when you’re in reverse (and some cars only do have one reversing light) surely that should suffice.
Postby RonR » Tue 14.05.2019, 18:21
David, Just to check - does this mean we could get some white rear indicator lenses made like Clemo has fitted to his JC Special?
Link to FB photo of Clemo's car
If so I think there could be more than a few people interested.
Postby M100TURBOFR » Tue 14.05.2019, 19:34
Hi
As stated, the "cover" supplier can supply all the lenses of the rear light cluster, irrespective of side.
Fredjohn : (sorry I don't know your name) No problem for supplying the white transparent "reverse light " lens. Just specify what side is required, as they are apparently side-specific. Indeed, you would need to be careful dismantling. I'll actually be receiving a quote tomorrow for a pair if it's of any interest to you. A single side can be purchased.
Ron R : I don't see why not. You do mean the side curved lens (Indicator) which normally is amber coloured. Is that correct? That would suppose the use of an orange bulb instead which isn't a problem.
I can ask if you're interested. That would naturally be both sides.
P.S. to BCN : The deformation does not concern my car. It's somebody elses. Thanks for the offer.
M100TURBOFR
Postby Saltire » Tue 14.05.2019, 19:47
M100TURBOFR wrote:Ron R : I don't see why not. You do mean the side curved lens (Indicator) which normally is amber coloured. Is that correct? That would suppose the use of an orange bulb instead which isn't a problem.
I have the same clear lenses fitted o my car, and I use Osram chrome bulbs, so the whole thing looks completely clear. It’s only Amber when you turn it on.
Postby RonR » Wed 15.05.2019, 10:17
Yes, it's the curved normally amber ones, both sides.
If you could get a quote for a pair and possible volume discounts that would be great.
I feel another list coming on.....
Postby Rambo » Wed 15.05.2019, 11:15
M100TURBOFR wrote:Fredjohn : (sorry I don't know your name)
David - the clue is in the 2nd part of the name :wink:
Postby uk08462 » Thu 16.05.2019, 16:08
Warped lens is on my S2. It's not had an MOT since I noticed it but I wanted to change the lens because it looks cr@p and just in case it's an issue at MOT time.
David has been fantastic in helping to sort this out for me.
S2 #048 BRG
uk08462
Postby Brit-Car-Nut » Thu 16.05.2019, 17:07
PM sent
Postby M100TURBOFR » Tue 21.05.2019, 07:59
Following the interest expressed by Ron R and Fredjohn for the rear light cluster lenses, please now refer to my new post regarding this subject "Rear light cluster lenses - Remanufacture - Availability".
Again, for the time being, this post is intended to gauge interest for these parts.
Can someone tell me how to link this "Deformation" post to my new post so that a "rapprochement" can be made between the two.
Thank you.
M100TURBOFR
Postby John_W » Tue 21.05.2019, 09:57
Here you go, David: follow this hot-link.
