ABOUT THE SEALS
ABOUT THE SEALS
Postby natefred » Fri 07.02.2020, 10:51
HI , i want to change the seals i think i need to change all the seals and i need to chang the hood too , my car is a 1990 one , i find some pieces "very expensive" to sjsportscar but i have some problems to understand what are the corresponding seals (i'm french)
can someone help me and give me a list of the necessary seals for the doors, the hood and the trunk, and do you know if the two trunk seals go for a 1990 model because the price is very different?
if you have a cheaper or better quality alternative to offer me (jamie ??) I am interested because it is out of budget
thank you in advance :cheers:
natefred
Re: ABOUT THE SEALS
Postby djwazza68 » Fri 07.02.2020, 14:34
Check out my post on the A-pillar seals, near the top of this part of the forum. I found that Renault Megane hard-top convertible seals are cheap and fit perfectly with some limited cutting and sanding.
I also need to remanufacture new side seals and will post my progress.
djwazza68
