and how the top curved part gets damaged by the Intermediate seal when closing the roof, so I came up with this idea... Lets remove the curved
part from the FPS and put it on the 1 piece removable hood seal, this combined with the one piece header / A pillar seals then creates a roof which
folds with only the straight section of the FPS attached, no other seals on the roof at all which means no seal is fouling another during closing as they do with the originals.
Now you would be forgiven for thinking that unclipping seals to lower the roof would be a bit faffing about, but to actually see it done and how
quick and simple it is you would be extremely surprised, the way the elongated new seal is designed to fit with the header and the FPS means it just
slips on precisely and only 1 single U shaped sprung stainless clip is needed to hold it firmly and accurately in place on the roof rails, once the hood latch is then
clipped shut its solid and going nowhere even before the glass is up against it. To lower the roof all you do is unclip the latch, unclip the seal and put it behind
the seat, it takes less than 8 seconds per side, the real beauty of these is how easy the roof then folds and no seals damaged in the process, there is also the added
bonus of the most watertight solution you will find on a fabric roofed M100.
This is the full setup in place showing how the top roof seal now has the curved rear part with the FPS now being a straight seal.
Picture showing the 1 piece hood seal removed...(its sitting on top)
Door closed and a very rare phenomenon occurs.... A watertight M100
This is an original FPS alongside the new version... Its been decapitated..
And this is the new FPS in place, this is now the only seal still connected to the roof as it closes, it makes contact with nothing else as it
folds shut. Overall its a lovely setup but the pictures dont really equate to how new and fresh it looks in reality.
