My RHD S2 has a curious passenger side headlamp pod problem. Every so often the pod does not lift, and once this has happened it never lifts again until I turn the manual pod lifting knob anticlockwise by the merest amount. Then it is OK until the next time that it is not – which doesn’t appear to be related to either elapsed time or the number of times the pod has been raised.
I’ve watched Toby’s REPAIRING THE HEADLIGHT MOTOR ON THE LOTUS ELAN M100 YouTube video and read the LEC’s headlamp pod message threads, so I know about the three plastic dowels that disintegrate, but this does not seem to be a problem associated with that failure, if only because the pod does work as advertised for 20, 30, or more times before having a hissy fit, and it does so just like the other one - without any hesitation or stuttering.
When the passenger pod does not lift:
* Neither the lighting switch or the headlamp flasher switch have the desired effect.
* The light always comes on. Not much good with the pod closed!
* The manual pod lifting knob does not move at all, it certainly doesn’t spin.
* The driver’s pod behaves as required.
When I turn the manual pod lifting knob just a couple of degrees anti-clockwise, to begin with it is tight and then becomes completely free. It is as though the last time the pod closed the mechanism went fractionally past the correct resting point, leaving it in a state where there is too much resistance for the mechanism to overcome the next time that I want pods up.
I read the Lotus headlamp adjustment instructions, but there is nothing to suggest that there is a home or resting position.
All suggestions gratefully received…
BdH
Tuross Head NSW
9-Jan-21 18:47
