Critter10 wrote:Can anyone recommend a good hood replacement company in the SW of England? I emailed TA & JM Coburn in Swindon, but got no reply and the phone rang off the hook. I'm after a really good tailor-made hood and am prepared to pay a premium if necessary.
Thanks in advance.
It's not just the hood you need, it's all the OEM seals which are no longer available (unless your name is Jamie and you can make better rubber ones
Also, the fitting of the new hood can be problematic so you are looking for a reputable source. Unfortunately I do not know one anymore, although it might be worth contacting SW Lotus, seeing as they are in your area, for their viewpoint.
I'm sure Allon White (Bedford area) does hoods, coach trimming etc....so it might be worth contacting them as well
https://allonwhite.co.uk/No affiliation to either company
