Aerial Base
Aerial Base
Postby TrevorB » Tue 04.02.2025, 21:02
Hi All, hoping there is someone here that can help with the procurement of an aerial base, probably a proper name for it, mine is disintegrating as shown by the picture.
If there is a part no. or similar replacement please let me know.
Many thanks
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Re: Aerial Base
Postby chrism » Wed 05.02.2025, 15:53
I remember looking for this a while ago and they were made by Bosch (I think) but no longer available.
I gather the special bit of it is a separate earth lead and I guess this could somehow be added later?
I hope 'someone in the know' can help...
chrism
Re: Aerial Base
Postby Tuga2112 » Wed 05.02.2025, 19:02
you aim for 100% originality dont you Trevor ?
i personally would investigate using a generic universal mast. but not the common type, because those wouldnt fit due to the presence of the washer reservoir
my yellow car just has a standard anteena in the boot and a rubber grommet blocking the hole. i personally think it looks better that way.
Re: Aerial Base
Postby TrevorB » Tue 11.02.2025, 12:28
Just to let you all know that I sent messages last week to the following with photo and enquiring about whether it was available:
LotusBits Ltd
Classic Team Lotus Parts
SWLC Performance Ltd
SJ Sportscars
I had reply from SJS and not available.
SWLC said that they would check but haven't come back to me.
No response from LotusBits and Classic Team Lotus, which is disappointing.
Tuga2112 wrote:you aim for 100% originality dont you Trevor ?
my yellow car just has a standard antena in the boot and a rubber grommet blocking the hole. i personally think it looks better that way.
Joao, I like your idea and have also been looking at other generic masts. So search carries on.
:cheers:
Trevor
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Re: Aerial Base
Postby Tuga2112 » Tue 11.02.2025, 14:53
if i was doing it. and taking into account how covers never get along with rods sticking out of the body panels.
I Would be considering buying a motor unit from a gen 6 Celica or mk2 MR2
im sure theres plenty others that would fit the bill. but those are the ones i know from personal experience, the point is.
1 - they are the style that has a motor and retracts
2 - the motor is not in line with the mast. therefore it is positioned a bit further away from the bodywork than the universal types. (see this listing to get an idea of what i mean)
in the M100 you probablyt can put a celica mast with the motor tucked behind the washer fluid reservoir. the whole stick up and retract electronics are also something you can get from a scrap car and just connect the signal wire straight from the radio...
anyways i really dont get the impression your the type of person to do something like that... and well.. the reason the answer is so ready for you... its because the mast on my NA is also broken. and i done your research as well.. im just not financially ready for the investment, mainly because i havent listened to radio in my car for.... probably 6-7 years now
Re: Aerial Base
Postby chrism » Tue 11.02.2025, 16:28
Adding to Tuga's solution, here's mine:-
I've got a DAB set and this is a cheapo plastic eBay aerial that lives in the glovebox most of the time.
Weak signal when working in the garage - so then I lay it on the dashboard or hang it over the rear view mirror...
Anyway who with an m100 motors along listening to the radio with the top off? :? :D
chrism
Re: Aerial Base
Postby Tuga2112 » Tue 11.02.2025, 17:44
chrism wrote:Anyway who with an m100 motors along listening to the radio with the top off? :? :D
some of us enjoy them on those days when elises are flung up into ditches :lol:
Re: Aerial Base
Postby wayne » Thu 13.02.2025, 02:39
TrevorB wrote:Hi All, hoping there is someone here that can help with the procurement of an aerial base, probably a proper name for it, mine is disintegrating as shown by the picture.
Many thanks
Trevor
I should have a used 1 Trevor, give me a few days to dig it out and check the condition of it.
http://www.elanm100.com
wayne
Re: Aerial Base
Postby TrevorB » Fri 28.02.2025, 20:51
So basically no progress with getting another base so decided to take it off and give it clean. Definitely looking better.
Photo's of old and cleaned up.
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Re: Aerial Base
Postby chrism » Fri 28.02.2025, 20:54
Aw...MUCH better :D
chrism
