by AJSGSE1990 » Sun 18.01.2026, 10:51
Hello all, have been reading about modifying MG hardtops and missing mould shells. Looking around there does not seem to be much beyond that and wanted to check if I am missing something obvious especially considering the demand there may be a secret squirrel group buy somewhere.
In a moment of madness, I thought of buying a tatty used soft-top, soaking it in resin and using it as a plug.
Thanks,
Andrew.
AJSGSE1990
- Tinkerer
by Simon_P » Sat 31.01.2026, 13:37
Some years ago I looked into making hard tops and did what you are doing - I kept it for ten years and then threw it away about 5 years ago.
The biggest problem is the steep rake of the windscreen a slight change between cars gives a big tolerance, so making something fixed won't fit between one car and the next. Same problem with the side windows although this is easier to fix.
I made my mock-up having spoken to professional moulders and realised it would be time consuming and expensive, I also realised that modifying the MGF hardtop solved the problem above as the areas you need to alter get remade to fit your car.
If I was doing it again I would start with an MGF hardtop and modify that to suit the shape I wanted to achieve and then make a mould from that, the soft top isn't the right shape as a starting point.
Have fun!
by AJSGSE1990 » Sun 22.02.2026, 10:22
Simon_P wrote:If I was doing it again I would start with an MGF hardtop and modify that to suit the shape I wanted to achieve and then make a mould from that, the soft top isn't the right shape as a starting point.Have fun!
Understood, thank you for the tips. I have two years to turn this into a daily, so will keep an eye out for an MGF hardtop.
Otherwise, my current plan is simply to block the operation of my spare hood as the issue sits (as far as I understand) with the seals that have to be cut to cope with the movement/folding of the top. If the top does not fold, then I should be able to use continuous top cover to window seals. Also, I should be able to stitch in a glass rear window.
Cheers,
Andrew.
AJSGSE1990
- Tinkerer
