Sun faded paint
Sun faded paint
Postby pte123 » Thu 16.07.2026, 13:13
Hi All,
I have a 91 Calypso Red that I just bought. The paint is quite faded in some places. Has anyone had any success polishing it out with cutting products? I want to see if it's going to be worth it, or it just fades back right away. Thanks! Phil.
pte123
Re: Sun faded paint
Postby dapinky » Thu 16.07.2026, 13:45
It is 'one of those things' with the type of red paint used by GM at that time (look at Astras, Cavaliers etc).
What you can do about it all depends on what has been applied in the past - if it is still a solid paint, it will respond to T-Cut (the red bottle original version) - but every time you use it, it will remove a small quantity of paint, so it isn't a 'lifetime' way to do it.
Once you have cut it back, you can apply a UV protection coating to preserve it for a bit longer...... but it will eventually need doing again.
However, if the paint has been covered with a clear-coat lacquer, it won't improve with T-cut.
The only realistic long-term approach is to get it painted with a modern formula paint, but that is an extreme thing to do.
Re: Sun faded paint
Postby pte123 » Thu 16.07.2026, 13:58
Thanks Dave, I guess I'll give it ago in a non-conspicuous area and see the results! A previous owner did pain the spoiler and the color matching is way off on that one, so it's likely headed to the pain shop at some point. Cheers Phil.
pte123
Re: Sun faded paint
Postby Tuga2112 » Wed 22.07.2026, 14:56
i rmemebre in 18 or so at the NEC classic car show. they had one of those astras in what looked nearly white in the first day, right at the entrance of one of the pavilions, at the end of the day half of it was bright red.
at the end of the second day it was all full red.
incredible feat of marketing.
